1.9 tdi 130 no power when cold
Ian2012 Nov 26, 2013
  1. Ian2012
    Ian2012 Active Member
    473
    29
    I have posted this in the A3 8 L section but i as this engine crosses into B6 would your advice too. Basically when the car is stone cold it has no real power like the turbo isn't working, then after 2 or 3 miles bang it's all ok, no codes at all vcds?
    What gives?
    Ian
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    could be the oil viscosity been too thick not allowing the turbo to spool up properly
    mine is a bit sluggish for a mile or so if its really cold
    have you got the right grade of oil in too?
  3. Ian2012
    473
    29
    Don't know to be honest it's due a service now and i have only just bought it, my other 1.9 engined car doesn't suffer from this!
  4. stu_m
    1,441
    Give it a service and see what its like after it
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    To be fair engines need nursing from cold, I wouldnt be trying to make any real power before it has warmed up.
    On my old Ibiza Cupra (1.8T) boost and fueling was limited before it hit a certain temperature - it may be the same case here?
  6. Ian2012
    473
    29
    Interesting idea i will see what it's like today, i am going to try Mr Muscle turbo clean as well to see if that will make any difference.
  7. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    I would give it a full service and also change the fuel filter
  8. TwedA4
    TwedA4 Member
    111
    mine is a bit like this sometimes. only had it a few weeks so though it was normal. but as it's been frosty for the last few mornings i start it 5 mins before i need to leave and it's been fine. :)
  9. YSN
    YSN Member
    93
    My B6 is similar, when it's totally cold in the morning shifting gears is also a bit stiff so just drive gently for a while until the engine has had a little stretch. But I would suggest maybe you check your engine oil have you had a recent oil service or anything or has this problem just started?
  10. Ian2012
    473
    29
    I have only just bought it, i will give it a full service tomorrow see what happens then
  11. Mike.M
    2,510
    170
    Don't forget the fuel filter :) for peace of mind
  12. Ian2012
    473
    29
    it's gonna be replaced tomorrow
  13. Ian2012
    473
    29
    The Mr Muscle clean has so far sorted this problem out, it was a symptom of the sticky turbo vanes
    TwedA4 likes this.
  14. TwedA4
    TwedA4 Member
    111
    nice one! i may have to do this too... i've noticed mine is a bit sluggish even when warm, other times it's off like a rocket!
