1.9 tdi 110 loses power sometimes
tara_nta Dec 11, 2011
  1. tara_nta
    tara_nta Member
    59
    I have a 1999 a4 tdi, for example when I join a bypass from second gear, bury my foot to the floor and go up through the gears, by the time I'm ready to go into fifth I've lost turbo power. It still drives but it's as if the turbo stops working. If I dip the clutch and flick the engine off, give it a second and start it again it's absolutely fine!
    Any ideas?
    Thanks in advance
  2. sportstractor
    sportstractor Chugger
    2,709
    Stick vanes in the turbo is fairly common, could also be a dodgy MAF or a boost/vac leak. You can get a fuel treatment to help with the stick vanes. This is all speculation though and your best bet would be to get it scanned for fault codes
  3. tara_nta
    tara_nta Member
    59
    Now you say boost leak/vac lines, my vac lines look like the originals and don't look to be in the best condition. Will change all vac lines for fuel hose. Sticky turbo vanes............is that a turbo off job?
  4. sportstractor
    2,709
    Well turbo off and clean is the ultimate answer. But like I said, check for codes if you haven't already?
  5. murdoch
    murdoch Member
    44
    try this , its quite easy really, definitely worked for me !
  6. willowsdad
    willowsdad Sideways
    1,027
    32
    I had similar symptoms on my transit van, I thought the turbo was shot. Turns out it was just water in the fuel filter. Quick visit to the garage and next day it was back good as new.
  7. Jason_E
    Jason_E New Member
    MAF is common thing to go spastic on VAG diesels. Actually, it's common on most diesels lol.
  8. tara_nta
    tara_nta Member
    59
    Just had a service inc fuel filter, for now I'll change vac lines and get a MAF. After that I'll have a go at doing the turbo
    Cheers for the advice
  9. sportstractor
    2,709
    Maf is common to go wrong on anything with a maf I'm afraid. I read somewhere they only read reliably for 2 years, and they are a sod to test which makes things worse
