1.8TQ suspension advice
Pontio Mar 14, 2005
  1. Pontio
    Pontio Member
    209
    Hello there everybody. I have reached the stage were i am now going to get a lowered/stiffened suspension for my car. Should i go for fully adjustable or a fixed drop and damping? there are the obvious advantages but i'd only leave it in one setting for the rest of its life anyway.. I dont only want the drop for looks but for handling also.
    I have 225/40/18 rubber on my car on ET 35 so how low can i go without problems?
    I am considering uprating my rear anti roll bar too, any recommendations?
    Sorry for the long and boring post, all help appreciated.
    Thanks in advance
  2. Pontio
    Pontio Member
    209
    any1? :-(
  3. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    A well proven successful suspension set up is:
    Bilstein or Koni shocks
    Eibach or H&R springs
    Neuspeed front and rear anti-roll bars or VW Golf 4Motion rear anti-roll bar
    All depends how much you have to spend. If money is no object and you want a great setup, go for the Neuspeed front and rear ARBs, Bilstein shocks and EIbach or H&R springs. That setup along with some negative camber will have you wondering why you didn't do it sooner!
  4. Pontio
    Pontio Member
    209
    i know the front anti roll bar is a pain to do and im not all that bothered about it, i'd like to change the rear though.
    Why different makes for shocks and different for springs? i was looking at a bilstein kit to be honest..
  5. Grant
    1,206
    118
    I have Bilstein shocks and Eibach springs.
    Most people go for Bilstein's. Choice of spring is down to personal choice. Either way, you won't be disappointed!
  6. olekvi
    olekvi Member
    68
    I will try koni coilovers on my TQ (if they'll ever arrive...)
  7. Pontio
    Pontio Member
    209
    are they fully adjustable or just stiffness? how much of a drop have you had and on what size rubber?
    Sorry for all the questions but all help is appreciated.
  8. imported_DeadEye
    imported_DeadEye Guest
    Could someone also explain breifly what coilover means?
    Has anyone fitted a nylon bush kit (to tighten things up that last bit)?
    Ta :)
  9. ANDYTQ
    ANDYTQ Well-Known Member
    1,177
    101
    Avo have a reputation for going wrong ,a mate with a g60 golf has had about 4 sets under warrenty,buy cheap buy twice! /ubbthreads/images/graemlins/beerchug.gifAndy
  10. RacingTeatray
    RacingTeatray Freezing in Moscow
    249
    How much are we talking for springs and dampers fitted? On a "money definitely is an object" basis....?
  11. ANDYTQ
    1,177
    101
    For bilstein shocks £450 ,h&r springs £130 plus fitting so not cheap ,but these are the ones that the s3 guys seem to recommend as having the best ride/handling ,as i said if you buy cheap you end up buying twice i speak from experience. /ubbthreads/images/graemlins/beerchug.gifAndy
