1.8Tq loosing coolant
1.8TQ Jan 23, 2009
  1. 1.8TQ
    1.8TQ New Member
    hey
    I have a 96 1.8Tq that's loosing coolant, there doesn't appear to puddles under the car and the rate at which the coolant is lost isn't particularly high (low coolant light comes on every 2 weeks approx), ive read about the water pump impeller being the possible cause of this but cant understand how that would cause the problem, the temp gauge doesnt shoot up ever and there doesn't apper to be any indications of it being the head gasket.
    is there any way to establish if it is the water pump or head gasket?
    oh and theres 118k on the clock and the belt (and maybe the w/pump) was changed at 115k
    cheers for any help
  2. Lee Goodall
    Lee Goodall Active Member
    2,279
    Can you take the under-tray off to determine where the water is leaking from?
  3. audinary
    audinary Complete And Utter Member
    676
    First place I'd look is where the coolant pipes meet the rad. When I changed my thermostwat and water pump it all pissed out on my first test drive 'cos muggins hadn't quite put them back hard enough.....
  4. aragorn
    18,369
    828
    ours does this too, albeit a little more slowly
    I've noticed crust on the top radiator hose and in one corner of the radiator itself, so i presume that when it gets particularly hot stuck in traffic or whatever the pressure causes it to leak a bit. I've enver actually had a low coolant warning though, and i accidentally left the plug undone for months after one oil change with no warnings from the dash whatsoever. The level never seems to drop below the minimum mark on the resovoir either.
  5. 1.8TQ
    1.8TQ New Member
    i'll check those out now
    cheers
  6. fatal8446
    fatal8446 Member
    95
    i had this problem, turned out to be a cracked plastic pipe attached to the engine at the back of the engine bay where there is a temp sensor. It made me chuckle cause when i went to get a new one from the dealership (only £12) and they called it a flange :haha:
    small things lol, hth
  7. Markey
    Markey Active Member
    2,175
    I had this problem as well i was putting about a litre in a fortnight, it turned out to be a tiny crack in the radiator. Look for white residue around pipes on the rad etc as this is teh dried antifreeze.
  8. Siena
    Siena Active Member
    2,626
    A leaking radiator core may be a bit harder to spot, especially if it's between the radiator and air con condenser.
    I doubt it'll be a pipe / hose, most common source of leaks on B5's is where the radiator core goes into the end tanks.
  9. billybravo
    billybravo Active Member
    1,045
    check your oil as well make sure its not going in there from the oil to water cooler just a quick idea
    but the rad is your best bet as said above
