1.8t wastegate?
hitman1978 Jul 13, 2012
  1. hitman1978
    hitman1978 Member
    119
    I've got a very audible air release/whooshing sort of noise when my car hits peak boost (23psi) from low revs, once I'm giving it some it doesn't overboost and runs around 18psi, I've been told this could be my wastgate not holding pressure, it still has a slight fluctuation in boost pressure aswell, could this be a result of my n75 needing replacing? Thanks
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Dv valve is shot if it's whooshing, you won't hear a waste gate .
    If the waste gate was faulty you definitely wouldn't hit 23 psi.
  3. hitman1978
    hitman1978 Member
    119
    I thought dv but got told its more likely that the wastgate isn't holding pressure properly
  4. hitman1978
    hitman1978 Member
    119
    Hi, I refitted the stock dv, same thing happened, now got a new forge dv and still the same, could it possibly be the n75 going bad, it also still fluctuates between 15 and18psi and you can feel it holding back, only other thing I can think is inlet manifold leaking somewhere, my boost gauge connects from vacuum line on inlet?
  5. hitman1978
    hitman1978 Member
    119
    Or could it possibly be due to intake temperature which is why it still shows good boost?
  6. saxonblue
    saxonblue Member
    298
    15
    mine makes a mad sound too, ( mi did a thred on it)
    put its like a fast ticking, what causes that
  7. hitman1978
    hitman1978 Member
    119
    i did wonder about intake temps, it definately pulls better before its fully up to temperature, might have to try and clean out my intercoolers, anyone know if this is a difficult job to do? also if i fit a intake temp gauge where would i fit it from and what sort of temp should i be looking to achieve, thanks
  8. olly quattro
    olly quattro Member
    78
    you can log intake temp on vag com, had a leak on mine and that was teh "suction jet pump" big plastic valve with nrv's in it at teh back of the inleyt manifold near cyl number 4 neearest bulkhead on top of engine
