1.8T Vag fault list
S4_dan Nov 2, 2008
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,762
    167
    Hi,
    Recently purchased a 1.8T Sport, 2000 'W' reg.
    Did a vag scan and the following faults have come up:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Address 01 -------------------------------------------------------
    Controller: 4B0 906 018 AA
    Component: 1.8L R4/5VT 0006
    Coding: 04001
    Shop #: WSC 06335
    2 Faults Found:
    17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
    P1116 - 35-00 - -
    16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
    P0134 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03 -------------------------------------------------------
    Controller: 8E0 614 111 AB
    Component: ABS 5.3 FRONT D00
    Coding: 0273004281
    Shop #: BB 24548
    2 Faults Found:
    00290 - ABS Wheel Speed Sensor: Rear Left (G46)
    35-00 - -
    00597 - Wheel Speed Impulses: Deviation
    Address 08 -------------------------------------------------------
    Controller:
    Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8D0 920 980 A
    Component: B5-KOMBIINSTR. VDO D11
    Coding: 00444
    Shop #: WSC 00000
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1345191
    1 Fault Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    27-10 - Implausible Signal - Intermittent
    Address 25 -------------------------------------------------------
    Controller: Bitte Adress
    Component: e 17 eingeben
    No Faults Found
    or DTCs not supported by controller
    or a communication error ocurred
    Address 35 -------------------------------------------------------
    Controller: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D13
    Coding: 13130
    Shop #: WSC 06335
    No fault code found.
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00101
    Shop #: WSC 06335
    Address 56 -------------------------------------------------------
    Controller: 4B0 035 186 E
    Component: Radio 0001
    Coding: 00017
    Shop #: WSC 06335
    End -------------------------------------------------------
    Is the Lambda sensor the on which is visible just below the air box? If so, where is best place to buy another or is there and upgraded one i can purchase?
    As for the ABS, im going to visually check the abs ring/sensor first.
    cheers,
    Dan
