1.8T Sump Gasket
Sam_ Jul 28, 2011
  1. Sam_
    Sam_ Down under
    3,038
    480
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I thought it was just sealant, never seen a gasket for one...
  3. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    Yeh it is supposed to be sealent on there. But i think it should work just as well. all the bolt holes are all close together so its unlikly it would blow out or anything stupid
  4. Sam_
    Sam_ Down under
    3,038
    480
    I know the norm is to use sealant but I want a solution which is going to guarantee a non leaking sump! I've done a few before and they're always a pain with pure sealant. I'll give VW a bell in a bit and see what it costs and if they can get it...
  5. <tuffty/>
    21,565
    4,045
    VAG sealant is the best stuff.... never had any leaks on any sump I have done using the stuff... use the stuff on mine... never leaked... not even a weep..
    <tuffty>
  6. Scruffydubber
    Scruffydubber New Member
    17
    I agree with the above comment. I've done around 3 now with the Vag sealant. Works great
  7. Sam_
    Sam_ Down under
    3,038
    480
    Alright well I'll give it a go. I was just looking for an easy way out. I have bought the proper VW sealant (renzosil). I guess a standard bead around the inside of the bolt holes is enough then?
  8. s3dave
    10,110
    736
    Yes that will do it
  9. <tuffty/>
    21,565
    4,045
    Seeing as I was fititng a sump today I thought I would take a few pics to help out...
    Thin bead of sealant in the center of the flange going round the inside of the bolt holes...
    ...when bolted up the sealant will squeeze out... if you use too much then it will be doing the same on the inside as the outside... this could break off and float around the sump so make sure not too over do it...
    ...the two inner bolts on the gearbox side of the sump are a git to get too as they are offset from the access hole...
    I use a 5mm ball ended allen key (in this case a 3/8 rachet) to start the bolt in using a blob of grease on the end to prevent the bolt from falling off then do it up using a 1/4 wobble extension and 10mm socket as the 5mm allen key can round...
    ...and there we have one 'sealed' sump :)
  10. Sam_
    Sam_ Down under
    3,038
    480
    Awesome thanks for that mate. I'll be doing this soon to replace my pickup. It's been serviced very regularly but can't do any harm.
  11. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    I used Loctite Flange sealant when fitting my sump, Worked a treat and fitted a sump to a transit connect with the same stuff and worked great.
  12. Y83OLK
    Y83OLK Hulk Smash!
    841
    i wouldnt use anything other than the VW sealant. (cant remember my last tube being called renzosil)
    However, i have never had one leak on me.
    *Also nice sumpy tuffty, yours baffeled?.
  13. Dubstep
    Dubstep Member
    54
    Ill be dropping my sump shortly to change the pickup pipe and give it a good clean, very tempted to take it to a local metal fab to have it baffled.
  14. <tuffty/>
    21,565
    4,045
    Not mine sadly... was fitting that one to a customers car...
  15. Y83OLK
    Y83OLK Hulk Smash!
    841
    also snap-on do a lovely 6" long 5mm ball ended allen key (3/8"dr) which makes the two awekward bolts a doddle.
  16. s3dave
    10,110
    736
    Any decent branded sealent does the trick, as tufty says dont overdo it it ...less is more....
  17. Sam_
    Sam_ Down under
    3,038
    480
    Well this is made by Victor Reinz, the OE gasket manufacturer if I'm not mistaken? It says "approved for all european and japanese vehicles, eg. .... VAG" and it's the right stuff by the looks of it.
    Do you guys let it partially cure before for a few minutes or whack it straight on?
  18. s3dave
    10,110
    736
    straight on sam......
  19. bazil
    bazil BOOM BOOM
    135
    straight on as said then i was told/read to leave it for 40 mins before adding the oil to allow the sealant to bed without coming in contact with the oil
  20. Sam_
    Sam_ Down under
    3,038
    480
    I'll be leaving the oil out of the engine overnight while it cures anyway...
