1.8t - S3 - cleaning hydraulic lifters
AGU-TURBO Apr 20, 2011
  1. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    Hi all if you have read my other thread you will no i have some funny noises which i think is the timing chain. ive ordered one of those and a new chain. but why i have the head in bits im wanting to no if the lifters can be stripped and cleaned. ive got them socking in petrol at the moment to try and clean them but would be best to strip them if possible. its costing alot of money at the minute so i want to eliminate all possibilities. thanks for reading
  2. Imteyaz
    Imteyaz 6th Gear
    535
    Have a read of this : FAQ - reconditioning your tappets..... - Club GTI
    I must admit to trying this on my old Golf GTI but failed at the first hurdle - I couldnt get the centre plunger out and ended up buying new ones instead. Lets us all know how you get on!
  3. AGU-TURBO
    616
  4. Broken Byzan
    13,237
    465
    a slow compress in a vice will allow them the drain, then you can try the "Bashing" trick.
    I mean slow though, takes ages per tappet.
  5. <tuffty/>
    21,010
    3,770
  6. AGU-TURBO
    616
    just been out to garage and had a play and they wont budge. will try and drain them first and see what happpens. also normaly on other cars i usualy tap the centre to see if they move freely. non of these move at all, there is no bounce. they carn't be all f**ked
  7. AGU-TURBO
    616
  8. Andrew@A.L.D
    3,877
    617
  9. Broken Byzan
    13,237
    465
    I would assume they are still of oil. A slow squeeze in a vice will drain them, then i bet they will be bouncy then
  10. <tuffty/>
    21,010
    3,770
    Erm... dunno exactly as I got them through Badger5 but not much more than a week IIRC...
  11. AGU-TURBO
    616
  12. aragorn
    18,139
    765
    Last few items i've imported from the states have taken about 3-4 days to reach UK customs, and then about 2 weeks to get from there to my door.
    I also tried the "smash the lifters on a flat surface" trick, and also failed. Dunno if its something thats changed in the lifter design from the old golf lifters in the link, or if i just wasnt trying hard enough though.
    The lifters out of the TT engine i've just put together were also "hard", i expect thats just normal when they're full of oil.
  13. AGU-TURBO
    616
    Ok right ive got all the oil out and they will only move the slightest bit. still wont bounce though lol. ive never messed with 1.8ts before so i don't no if they are supposed to be like this or not. as every single one is the same i would say they are but would like confirmation on this.
    Many thanks for replys
  14. AGU-TURBO
    616
    carb cleaner is the answer lol, reacts straight away to the oil and it poors out. gave them a good squirt put in vice and went back n forth with it and eventualy they free up
  15. Sevv
    Sevv Pushing the limits..
    1,321
    118
    hello guys ive tried searching on the forum for any thread concerning oil lifter noise especially when u trunt he car on first thing in the morning to warm up and its a loud thumping or ticking noise straight on the top of the engine on the right side that is next to the drive belt etc..
    is it old age , normal or should be looked at as she's going to get a clutch and flywheel upgrade next week.
    cheers in advance for any pointers :)
  16. AGU-TURBO
    616
    Sounds like you have a lifter that's not holding preasure. when you leave it over night all the oil is draining out of 1 of them, you could do with it getting looked at.
  17. Sevv
    1,321
    118
    Hi matey , i think you're right though its only over long priods that the car is off. i have a video recording not that u can see anything but a audi and it almost sounds like a bloody air compressor. ive noticed this after an idiot of a mechanic fixed rocker cover gasket on my car only to break my dip stick and tube. and fit my tyers the wrong way. Mechanics in australia seem to be complete idiots when it comes to VAGs.
    thats the link
    DSCN0348.mp4 video by sev19489 - Photobucket
  18. AGU-TURBO
    616
    lol. Yeh definetly a lifter, take you'r rocker cover off first thing in the morning and push all the lifters down with a handle of a screw driver. they all should be pretty hard, The one that moves easily will be the f**ked one. failing that get some fealer gauges and check for clearences
    Giovanni saieva and Sevv like this.
  19. Sevv
    1,321
    118
    ah thanks matey this car has cause me so much troubles ive change 2500$ AUD worth of equipment on the car from timing belts clutch flywheel battery injectors, coil pack , and the HT leads gasket and rear main seal im fed up lol. any way besides my *****ing do u know time wise how much time it will take as its going for a check up on Thursday this coming week for clutch replacement
  20. Sevv
    1,321
    118
    ah and i forgot if it continues which im not looking at that happening what can get damaged ? engine wise sorry im a bit of a noob
  21. AGU-TURBO
    616
    you might get increased wear on your cam lobes or worse as the lifter won’t hold pressure there is obviously something wrong with the bearing in the middle so what could happen is it could over pressurise and cause piston slap which would result in the head off new valves fitted at least
  22. AGU-TURBO
    616
    To check the lifters about 30min - to replace depends on which side. inlet side is easy and wont take long at all - exhaust side is a bit different as you need to take the cam belt off. it took me roughly 2 hours to replace the cams - lifters and fit new timing belt
  23. Sevv
    1,321
    118
    thanks matey appreciate it.. not even having fun with this car hasn't even run 2000miles since i owned it and all these problems have risen
  24. AGU-TURBO
    616
    I no how you feel mate had a few cars in the past that are money pits
  25. Sevv
    1,321
    118
    yup its ridiculous i dont know how much it will cost me as i dont have the tools yet to fix the car though i have the HANS manual lol. been think on this A3 wether if i were to change the engine on it put a 1.8T would the gearbox be the same ( change ratios that is ) and would the starter motor, alternator wiring loom ecu etc... or do i have to change them accordinly. cheers
