1.8T QUESTIONS
jaffaxr Mar 8, 2014
  1. jaffaxr
    jaffaxr Member TFSI Owners Group quattro Audi A4 Audi Avant Owner Group S-line owners group Manual
    91
    9
    hi guys need a few answers if you can help?
    1. can you tell the difference between a 150 and 180bhp model?
    2. did they all have abs or only a few?
    3. if it does have abs is there a light on the dash that should go out?
    cheers guys and girls.
  2. Sulli79
    Sulli79 Active Member
    541
    37
    1. 180 Quattro only as standard UK model
    2. All
    3. Yes
  3. Broken Byzan
    13,237
    465
    what Sulli says.
    The B5 also doesn't get a k03's turbo so if you are told otherwise it's a lie,
  4. jaffaxr
    91
    9
    cheers guys where on the dash should the abs light be so i know where im looking?
    also are there any differences between a 1.8t and a 1.8t sport?
  5. Sulli79
    541
    37
    ABS light is just about in line with 70 mph here is a pic of a tqs as it's easy to see where they all are uploadfromtaptalk1394299672375.jpg should light up orange.
    1.8t sport, if we're talking fwd, have three spoke sport steering wheel, lowered sport suspension, sport seats, and 5 spoke 16" alloys. 150bhp
    1.8t Quattro sport has white dials, aluminum door and dash trim, unique half leather sport seats, black headlining, 17" bolero alloys,
    Front upper strut brace. 180 bhp
    Probably missed off a few bits, but that's most of it
  6. W33 TJS
    W33 TJS New Member
    27
    MMM nice reasdy i think i by the sounds of it i have the 1.8t Quattro sport as mine has white dials, aluminum door and dash trim, unique half leather sport seats, black headlining,
    But im not sure if mine has these
    17" bolero alloys,Front upper strut brace. 180 bhp
  7. Bradderz_1988
    3,958
    240
    If you have boost gauge you will see 10-12 psi if 180bhp and if you have a Quattro 1.8T then it will be 180bhp
    Boleros are these :-
  8. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    Front strut brace is behind the bulkhead(?) right in front of the battery. It's a flat metal bar going across the engine.
  9. Merlin1977
    Merlin1977 New Member
    Hi I hope this is where I post lol I have a 1999 audi a4 1.8t quot and having some problems I can only get 1 speaker working front near side any idears what is wrong or advice on how to fix this my wife's driving me crazy lol personally I like listening to the engine but you know what the woman are like lol thanks
  10. Bradderz_1988
    3,958
    240
    Speakers probably shot. Try swapping it to the passenger side see if it works on the other side.
    Mine did this swapped it out for a good one and it fixed it.
  11. Sulli79
    541
    37
    Have they ever worked?
  12. Merlin1977
    Thanks will try that now
  13. Merlin1977
    Not sure pal only had the car 3 weeks
  14. Sulli79
    541
    37
    Does it have Bose too? If it does should have little emblems on the speaker grilles. Also what stereo is it, should have a name like chorus or symphony?
  15. Merlin1977
    It has an alpine stereo in the audi looks like it has all the origanal speakers
  16. Sulli79
    541
    37
    Pull the stereo out and check the connectors, have you also checked balance and fade?
    Reason I ask about the Bose is if it had Bose originally the rears are driven by a seperate amp so rears won't work without some messing, if it doesn't have Bose I don't think you have those problems.
  17. Sulli79
    541
    37
  18. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    Mine is a 180bhp TQS - but unsure of the Strut brace Ive never seen one of these on the TQS I have seen - any pictures please..... Thanks
  19. Bradderz_1988
    3,958
    240
  20. Rallyman
    213
    oh thanks!
    Funny mine doesn't have this.... And that the first time Ive seen one! I've seen about 5 TQS's now All Avants now though.
    Is this on a Saloon?
    I cant remember what turbo is on mine - but I know it is a 180bhp model as it gave that on the rollers.
    Also the rear boot badges have a red under line on the boot lid and the T of the 1.8 T has a red vertical part.
  21. Broken Byzan
    13,237
    465
    The oem fitted strut brace doesn't use the strut top brackets. It mounts to welded points on the shell. It will be under the scuttle hiding behind the wiring
  22. aragorn
    18,485
    855
    Yeh it will be there, just quite hard to see.
  23. Iceash
    Iceash Member
    391
    10
    Does it make any difference?
  24. Broken Byzan
    13,237
    465
    you can see the end of it in this pic
  25. makster1978
    makster1978 Member
    82
    I have a 99 a3 1.8t sport I never new they did a 4wd model in this spec non quattro?
  26. Broken Byzan
    13,237
    465
    ?? These are a4's
