1.8T Quattro Idle porblems
Faz1.8Tquattro Oct 24, 2010
  1. Faz1.8Tquattro
    Faz1.8Tquattro New Member
    9
    Hi everyone,
    this is my first post so first of all hey!!!
    Ive got a 2001 A3 1.8T Quattro - ARY engine code I think. My car has recently been suffering from idling problems. The enginge really struggles to keep to around 1000rpm. I have read that it could be a number of problems such as split hoses, coil pack, various sensors clogged up.... but what is the best way to find out rather than just taking it to my local audi dealer???
    I've read on here that its a good idea to clean the throttle body but I'm slightly worried as i don;t have vagcom to reset it after i'm done.
    What do I do????? Any help would be gratefully recieved!
    Thanks,
    Faz
  2. talentwalsh
    talentwalsh Member
    139
    It certainly could be a number of things but start with checking the PCV system, especially under the inlet mani. Very prone to degrading, look at all the rubber hoses and the plastic joiners. While your at it look at the PRV (hockey puck valve) piping as these can collapse over time also. Without getting it vagcomd though you could be chasing problems. Best get it scanned first before doing anything further.
  3. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
  4. Faz1.8Tquattro
    9
    Cheers!
    I'm going to have another good look around today and attempt to clean the throttle body as well. I noticed a pipe yesterday that was unbelieveably soft - felt like jelly. I'll get a few pics up here in a bit!!!
  5. Faz1.8Tquattro
    9
    Got my car back from my local garage and they said they hooked it up to VAGCOM and noted the following error codes:
    1) 17704 Cooling system malfunction
    2) 17705 Turbocharger/throttle valve connection pressure drop
    3) 17545 Bank 1 mixture adaptation (too rich)
    4) 16514 Bank 1 Sensor 1 (electrical fault)
    They've cleared all the codes and it seems to be running much smoother.... lets see!
    I have noticed that the coolant temperature sensor is leaking a bit. I've read somewhere on here that if you want to change that you also have to change the "header tank" or something?????
  6. finesse
    finesse Active Member
    2,805
    Rough Running At Idle: MAF, Ignition Coil, Spark Plug, VAC Leak, O2 Sensor, TB, CTS
