1.8t Overboost problems!
marrick92 Apr 6, 2012
  1. marrick92
    marrick92 Member
    68
    Hi all,
    I have a 1.8t AGU, had a new K03s fitted the other day now every time i go over 4000rpm or put my foot down it jurks like mad!
    Plugged in the VagCom and it threw out:
    00544 - Maximum Boost Pressure Exceeded
    35-10 - - - Intermittent
    I dont think the n75 is to blaim, it wasnt doing it before i had the new turbo fitted.. could it be a badly adjusted actuator from the factory? if so has anyone got a idea on how to adjust this properly and safely?
  2. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    I always used to get that fault but never the jerkyness.what's the mileage of the ko3s,maybe you need a new atuator.
  3. marrick92
    marrick92 Member
    68
    brand new one mate
  4. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    You sure actuator actually opens? Is the pipe connected?
  5. Turbo unit
    Turbo unit Member
    93
    Were did you get the turbo from is it a genuine kkk??? have you got it mapped too?
  6. marrick92
    marrick92 Member
    68
    not been mapped, im pretty sure its a replica from ebay but it has a years warrenty which is why i got it.
    All the hoses are connected properly, i plugged a foot pump into the hose that comes from the actuator and it does open and close but im not sure what PSI its meant to open at?
    thanks for the help :)
  7. marrick92
    marrick92 Member
    68
    and is it worth trying to put the old actuator from my standard K03 on to see if that works?
  8. marrick92
    marrick92 Member
    68
    Just to bring a close to this thread for anyone who may have this problem in the future.. It was fixed by winding down the actuator by 3 full turns of the bolt. It ends up it came from the factory with the actuator set to overboost...
  9. a318t
    a318t Member
    My car is doing exactly this! Just had a brand new genuine kkk actuator fitted to my ko3. If I get up to around 4,500 revs and sit there, then put my foot down it just will not rev out! By that I mean it simple wont rev past 4,500. However, if I boot it right from the bottom at 1,000 rpm all the way to the redline, it works perfectly!
    I will adjust the actuator as you say and see if it fixes it!
  10. badger5
    9,540
    2,015
    disconnect n75 valve electrically and see what it boost to... (5psi is what it shoudl run)
  11. jamieA3
    jamieA3 Member
    150
    are thoese replicas any good ?
