conor page
- Joined
- Aug 29, 2016
- Messages
- 7
- Reaction score
- 0
- Points
- 1
Please Help...
I have been looking through the many posts about oil sensor/pressure issues but i haven't been able to find one with the same problem as i'm having.
I have a 2003 A4 Cabrio with 1.8T engine. It has approx 130k miles on it. I have only had it 6 months. It has always run great with plenty of power. When driving it a while ago the oil warning came on (oil can with 'min' beside it). I stopped the car checked the oil level which was a bit low but not at the minimum on the dipstick. I left the car for a few minutes and turned the ignition on and the warning had gone. I decided to stop and get oil anyway. Problem solved....or so i thought. After a few hundred km the same oil light came on again and went off after i had checked the oil level. I read up on the various websites about the oil sensor issues so did an oil change and replaced the sensor.
All was well until approx 1000km later when the oil warning came on again. I stopped the car and checked the dipstick and this showed the the oil level was approx 3/4 full. Warning went off after i had taken out and replaced the dipstick. Given that the oil level was ok i continued to drive and approx 100km later the light came on again. This happened a couple of times but oil level was fine and after replacing the dipstick each time the warning went off. I then filled the oil to the max on dipstick (only approx 300ml was required). After this the car was fine for approx 900km but the other day the light came on again but went off after i checked the oil level.
The car runs and sounds great. From reading through i know people have recommended cleaning the sump but when i changed the oil i didn't notice any gunk coming out and i flushed through some clean oil just to try and clear anything that was there.
I would really appreciate any advice....
