1.8T oil pump ??
Bradderz_1988 Aug 21, 2013
  1. Bradderz_1988
    3,947
    235
    Which is the correct part number for the AEB/AJL ??
    1.028115105M
    2.058115105CALT
    3.058115105C
    as my light came on again the other day after being in traffic for 5 minutes after getting off the motorway then went off as i pulled on the roundabout ?? Do you think it could be pressure switch playing up not plumed in a pressure gauge yet but thats on the list to do !!
  2. aragorn
    18,149
    766
    1. is for a diesel
    2 and 3 are the same number, one just as "ALT" on the end for some reason?
    058115105C is what you need anyway.
  3. Bradderz_1988
    3,947
    235
    Cheers mate thought it was just theres a number 1 on ebay genuine audi for £40 :( ... Bummer !!
    why couldnt it have been a 1.8T and not a bloomin diesel one haha
  4. Bradderz_1988
    3,947
    235
    Got my pump yesterday, now im in work tomorrow and thinking of doing it but ive got to do the rear wheel bearing that i think is goosed and also one of the rear diff seals unfortunately its the opposite side to the bearing .. Typical so ive got roughly 5 hours to do the lot now my question is how easy is the sump to do with the front end off on a 2 post ramp im thinking if it doesnt clear the subframe the ill just undo box mounts and use a jack to push the engine and gearbox up so it will clear or is it easier just dropping the frame ??
    any tips/pointers that would be of use will be great !!
  5. jimmcgee
    jimmcgee Active Member
    261
    40
