1.8t new internals.
Miguel_S# Mar 22, 2014
  1. Miguel_S#
    Miguel_S# Active Member
    337
    29
    hello people
    I have a 8l S3 with:
    Hybrid turbo (tfsi turbine and mfs compressor)
    3" downpipe and exhaust
    Badger5 exhaust manifold (requested iam waiting delivery)
    Bigger Injectors
    Big IC.
    Now i need some help because i have a AEB Head and 1.8t Block.
    i have doubts, i dont know what to fit in the block and the AEB head.
    I will fit 2.0tdi crankshat and 86.4mm pistons.
    Can someone tell me the best and lighter conrods and piston.
    About the head i want 8000rpm.
    what parts i need to achive this values
  2. Pedrosousa
    Pedrosousa Member
    174
    Bruto
  3. Broken Byzan
    13,237
    465
    Pistons will not fit
  4. Miguel_S#
    337
    29
    yes it fit, but we have to work bore
  5. Broken Byzan
    13,237
    465
    Not a chance. 83.5 is max on 1.8t block
  6. <tuffty/>
    21,782
    4,168
    I think you are a little confused my friend...
    86.4mm is the stroke of the std 1.8 crank... TFSI stroker cranks are 92.8mm stroke
    1.8t blocks can be bored to a MAX of 83.5mm but no one really goes over 83mm as its not reliable and largely pointless...
    To convert your 1.8 20v to a 2ltr you will need a TFSI crank from a petrol engine (not a TDi like you posted unless this is a typo) and 83mm bore stroker pistons... JE or CP pistons are the normal ones to choose from and 9.25:1 to 9.5:1 compression ratio depending on manufaturer
    As for 8000rpm capable head... you may want to consider an 8000rpm capable turbo first... you will also need cams to get it breathing enough too
    Valvetrain wise you would need a full supertech setup so single groove inconel exhaust valves, single groove nitrided inlets and valve spring set..
    Std cams and a K04 hybrid will struggle take make power beyond 7k rpm...
  7. Miguel_S#
    337
    29
    I want 8000rpm to improve top speed.
    i was hopping i only need valve guide to achive rpm....
  8. Miguel_S#
    337
    29
  9. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    If you want to get to 175ish mph in 6th gear (7,000+ plus) you will need a turbo that can produce enough power to turn those gears fast enough.
  10. Broken Byzan
    13,237
    465
  11. Miguel_S#
    337
    29
    I hope i can get 350hp at 8000 with This turbo
  12. badger5
    9,575
    2,038
    350bhp @ 8k?
    I dont think so.
    peak power will be at lower rpm
    Full uprated valvetrain for those revs.. and a nice balanced bottom end also
    TDi crank...?
    Hmmm
    Vex182 likes this.
  13. Miguel_S#
    337
    29
    TDI crankshaft Part # 038 105 021 E or equivalent
    IE 06A 1.8T 20V 2.1L 2067CC Stroker Engine Kit (8.5:1 CR)
    i hope my engine will have those values more 500rpm
  14. badger5
    9,575
    2,038
    you will have more torque, sooner, but as for peak power being achieved that high I suspect not.
    it will have diesel torque with some more revs to play with I think
  15. Miguel_S#
    337
    29
    So with a stroke i only win torque?
  16. <tuffty/>
    21,782
    4,168
    The TDi crank messes with the rod angles too much as the 20v block is shorter than the 1.9tdi block... I have reason to believe that the TDi cranks don't make very high revving engines and your 8k limit may not be achievable
  17. Miguel_S#
    337
    29
    its 2.0 tdi, IE used in thid stroke kit
  18. <tuffty/>
    21,782
    4,168
    That part code is for the 1.9TDi crank... the 2ltr TDi is a larger bore is all... 1.9Tdi is 79.5mm bore by 95.5mm stroke... 2ltr TDi is 81mm bore by 95.5mm stroke
    As I said... the extra stroke of the TDi crank messes with the rod angles which means the engine won't rev as high as using stock stroke or the TFSI crank...
    Andrew@ALD has done this build though...
  19. Miguel_S#
    337
    29
    Thanks for sharing knowledge and experience.
    For my goals what do you recommend?
  20. superkarl
    superkarl MAN OF STEEL
    9,590
    2,473
    Stock crank, 83mm pistons. ALL the headwork, IE intake cam.
    if you insist on revving and having ANY chance of making power past 7.5k
  21. badger5
    9,575
    2,038
    revvy... is to pump more airflow thru a small engine on larger turbo (aka badgerwagen)
    you should spec total flow output from the turbo to your motor.
    Why the 8k rpm - ?? whats so special about the rpm? (top speed vmax run or something?)
  22. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,296
    372
    because racecar
    Airs and superkarl like this.
  23. Miguel_S#
    337
    29
    I want the top speed is 300km/h
    How I spec total flow output from the turbo to motor?
    The compressor is a mfs tfsi 7+7
  24. badger5
    9,575
    2,038
    want top speed choose suitable gearing if this is your turbo choice.
    8krpm is spinning fast for 95.5mm stroker crank on 1.8t block
  25. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    186mph from a K04-023 hybrid....
    Is that even do able? :confused:
  26. Miguel_S#
    337
    29
    Thanks for the information
    i will keep ori crankshaft
    But Badger you have car mapped with 345hp at 7600rpm with no large head, its so hard to have more 400rpm?
  27. superkarl
    9,590
    2,473
    youre missing the point and misreading the dyno chart completely.
    where does it make peak power?
    it does not make any more power after 7k or so. At 8k it will nose dive faster than id **** dive on Amber Heard. Ie, pointless
  28. superkarl
    9,590
    2,473
    To add, torque dies at 6k, power at 6.5k. It is out of its efficiency range
  29. Pedrosousa
    Pedrosousa Member
    174
    Using the IE intake camshaft can he gain something? Or it's the turbo beeing the limitation???
  30. badger5
    9,575
    2,038
    you need to read the dyno plot better miguel
    peak power not @ those revs my friend
  31. Broken Byzan
    13,237
    465
    Nothing to gain from cam on this small frame turbo. Spend the money buying a bigger turbo instead
  32. Miguel_S#
    337
    29
    So the big problem in 8000rpm is turbo abilitie to flow the exhaust and exhaust temp????
  33. superkarl
    9,590
    2,473
    no, the ability to flow significant airflow above those rpms (turbo shaft speed). If you had a compressor map and overlaid rpm for your displacement you would see that at X rpm the turbo would be out of its efficiency range and hence be making no more power.
  34. badger5
    9,575
    2,038
    want top speed fit a diesel gbox..
    had a lc180 in last week, diesel box, owner was'nt aware it was, 5th gear 3krpm was 95mph.
    long legged mofo.
  35. Miguel_S#
    337
    29
    Thanks people.
    Now I understant, too keep power at high rpm it needs a big compressor wheel.
    Coating piston what do you think about this???
  36. Miguel_S#
    337
    29
    Thanks but with this gearbox the car will be more slow and i dont want that
  37. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I think you need a new car.
    kwistof and superkarl like this.
  38. Miguel_S#
    337
    29
    Funny guy
    when i do something i like to know why and learn because learning is a great thing
  39. Miguel_S#
    337
    29
    I was searching and found ARROWS conrods, but they are very expensive.
    Titanium connecting rods - Arrow Precision
    30% WeigHt saving
    Titanium grade 6AL-4V
    CrN coated
    Did the weight saving makes difference our is a waste of money?
  40. <tuffty/>
    21,782
    4,168
    On a road car with a K04 yeah..
    MexxT and Vex182 like this.
