1.8T Main Bearings - Oddity?
aragorn Mar 8, 2011
  1. aragorn
    18,036
    725
    So i'm slowly getting the parts together to build up the motor on the Shed.
    I've got amongst other things a set of Glyco main bearings, which have me slightly puzzled in that there are 6 bearings with a slot and a hole, and four bearings which are just plain.
    ETKA suggests i should have 5 of each type, with the holed ones going in the block, and the plain ones in the caps.
    At first i thaught it was a packing error, but google seems to have lots of other people with the same issue, and a vauge suggestion that its intentional and that #4 main should have both holed bearings...
    Can anyone confirm this?
  2. Audi2ptzero
    Audi2ptzero Member
    52
    They can come either way and is normal. The extra bearing with the hole/slot goes in the center, so between cylinders 2 and 3.
  3. aragorn
    18,036
    725
    Hmm thats different to what the Audi manual suggests, it says the extra hole/slot goes on main bearing 4, nearest the oil pump?
  4. Audi2ptzero
    Audi2ptzero Member
    52
    Odd. What I put is the info I got from the guys at IE.
  5. aragorn
    18,036
    725
    Yeh,
    ETKA is strange.
    If i look up a 2000 AJL model, it shows all 5 bearings have a grooved upper and plain lower section.
    If i look up a 1998 AEB model however, it shows one bearing set for 1-3 and 5, and another set for 4.
    The set for 4 has two grooved shells.
    No idea why bearing 4 (or 3 as you've suggested) would actually need a groove in the cap though :/
