1.8T - hissing from fuel cap?
niggtv Mar 19, 2006
  1. niggtv
    niggtv Member
    81
    Hi,
    I have noticed that when the engine is running there is a loud hissing coming from the petrol cap on my 1997 A4 Avant 1.8T.
    If I push the filler cap in the hissing stops, but then the idle on the car drops and it doesnt tick over smoothly.
    I have tried swapping the petrol cap itself incase this was all that was worng, but that didnt solve it.
    One last thing, the car seems to be very slightly hesitant - I had thought this might be the MAF, but am wondering if it linked to this problem somehow.
    Any ideas guys? Cheers
  2. madvw
    madvw Active Member
    2,489
    probably will be. Most of them will show the check engine light if it detects a leak here. The vapor from the tank is now recirculated, rather than vented into the atmosphere.
    you say you've tried swapping the petrol cap, was it for a new oem one, or a replacement get you home jobbie?
  3. niggtv
    niggtv Member
    81
    I replaced it with the fuel cap from my mate's A4... they looked exactly the same.
  4. madvw
    madvw Active Member
    2,489
    strange. It sound like there may be too much pressure then.
    Does anybody know if the petrol caps have valves in? If so, what regulates the pressure in the fuel tank recirc?
  5. Kevint
    Kevint Active Member
    1,182
    I had a similar problem on an Astra once. The car would stall every now and then though.
    It turned out to be a blocked vent pipe which was connected to the neck of the fuel filler.
    Kev.
  6. niggtv
    niggtv Member
    81
    Cheers, sounds like it might be something like a vent pipe.
    Has anyone had this hissing problem on an Audi, or suggest any other possible causes?
  7. niggtv
    niggtv Member
    81
    Well, thought I would post up the solution incase anyone else ever has the same problem. It was the recirculation/solenoid valve, which is located near the airbox in the engine bay. Part number is 058 133 517.
  8. Daveiow
    Daveiow Member
    264
    did it sort out teh car being hesitant as well ????
