1.8T engine oils lines
luis.filipe Dec 4, 2007
  1. luis.filipe
    luis.filipe Member
    85
    Hi,
    regarding the problem of white smoke on my car, is there
    another filter on the oil lines ? Something that can get blocked
    and cause some problems ?
    Thanks in advance
    Regards
  2. LaSarthe&Back
    LaSarthe&Back Member
    300
    Hi,
    water entering the exhaust or combustion chamber is the cause of white smoke. Oil will make blue smoke.
    What makes you think it's oil?
    Andy
  3. luis.filipe
    luis.filipe Member
    85
    I might be wrong, but the oil level was a kind of low.
    The coolant level on the other side was on the same level and I keep an eye on it frequently.
    When I saw the oil level and don't see coolant on the oil...
    If I have a coolant leak, where should I start looking at ?
    I've already made a compression test and haven't found anyhing strange on it
    so I doubt about the head gasket . . .
    Any ideas ?
