1.8T breaking...?
Geeman Apr 12, 2009
  1. Geeman
    Geeman Low Life
    1,318
    I'm after some standard boost/air pipes for my '00 1.8T to get it all back to standard.
    Anyone know of a 1.8T that's being broken for parts or have any pipes luying around that are available... please?
    Cheers,
    Giles
  2. aragorn
    18,373
    829
    What does your car currently have?
  3. Geeman
    Geeman Low Life
    1,318
    I have no idea. It's been 'butchered' a bit... (before me)
    I want the rubber pipe that runs from the air filter... the lower rubber pipe that connects to the front lower metal pipe (that runs across the front) that has the dump valve fitted to it... and the smaller diameter rubber pipe that runs from the ORIGINAL dump valve to the aforementioned air filter pipe.
    So I would like 3 pipes in all...
    On the Vag Cat diagram - 13 & 6 (with the extra smaller diamter wiggly pipe)
  4. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    6, 13 and 16 then?
    may be able to help with no 6, have a firge unit in place on mine.
    leave it with me, will dig out the shizzle that got boxed up when they fitted the FMIC.
    don;t need an intercooler do you?
  5. Geeman
    Geeman Low Life
    1,318
    No, not 16 at all... that's just the vacuum pipe to the inlet manifold... I need 6 (not 6a or 6b), complete with the extension rubber pipe that comes out the top that the diverter valve (14) connects to.
    I could really do with a new 13 as well though... just to make sure mine's not been butchered (as I think it has).
    My intercooler is fine (I think) thanks...
    I'm just frustrated with it. Grrrrrr!
  6. jcb
    4,132
    13
    WIll check. will be later this week though
    Its all boxed up inside a Mk2 Golf I am breaking!
  7. Geeman
    Geeman Low Life
    1,318
    Thanks!
    Where are you based fella?
  8. docurley
    4,071
    85
    I have a spare 13 if that will help i will have to have a loo for the rest.
  9. Geeman
    Geeman Low Life
    1,318
    I'm looking at a full Passat 1.8T tomorrow night. Hopefully I'll be able to get everything I need off that. If not, then I'll take up both your kind offers... if that's okay!
    Cheers,
    Giles
