1.8t boost level?
2pac Oct 23, 2004
  1. 2pac
    2pac E3 APC
    55
    Whats the standard boost pressure on the A3 1.8T, and S3, if different. I noticed someone on here had a ''1.4bar upgrade'' from one tuner. Compared to the jap cars I'm used too this is quite high and would require a very carefully set up fuel and boost controller arrrangment or even a seperate fuel managment system. I'm of the understanding these engine are VERY strong!
  2. PaulRS3
    PaulRS3 Well-Known Member
    1,218
    150
    S3 is approx 0.9 bar. standard
    A3's are less.
  3. foolish3uk
    foolish3uk Member
    455
  4. Markb
    Markb Active Member
    2,139
    Mine is boosting at .5 bar
  5. HTC
    HTC Active Member
    3,428
    9
    .5-.6 is about average.
    1.4 bar on a standard audi turbo would melt it in no time at all.
    You need a big turbo an big intercooler for that level of boost.
  6. NWMark
    NWMark Member
    211
    14
    [ QUOTE ]
    [/ QUOTE ]
    Do you mean all Audi turbos or just the A3 ones (K03 & K03s) as i know that most chipped S3's (K04) run at least 1.4 bar of boost!!
    Mark
  7. Danielson
    Danielson Member
    704
    im running spikes of 15psi then dropping off to 13 psi on my chipped a4. if its any help, its been chipped for over a year and nothing has melted yet..
  8. mlcadman
    mlcadman Member
    109
    mines set to around 12-13 psi, standard is around 6 psi on an a3
  9. Ryanc
    Ryanc Active Member
    1,321
    some s3's run 1.7 bar although not to redline, they all tend to drop to around 1 bar because the turbo can't hold the boost.Thats why you can't get much more 270bhp out of a k04 s3.The engines have forged pistons and a v.strong crank,the weak link are the con-rods which fail when severly pushed,hope that helps.
  10. 2pac
    2pac E3 APC
    55
    S3's have Forged pistons as standard, nice one. What about internal specs of the a3 1.8t. I heard they are strong enough to take twice there power, or is this person gettin mixed up with the S3 specs.
    I've never heard of a chipped car that looses 0.7 bar boost because the turbo can't hold it. Thats quite a dip in power. Is this not a fault with the map of the chip rather than a weak turbo. I'd hate it if my car lost that much boost
  11. Ryanc
    Ryanc Active Member
    1,321
    The turbo is just too small to hold the boost in the higher rpm range,you'll find alot of guys here running up to 1.7 bar but like i said it will be nearer 1 bar at redline.
    standard a3 1.8t's don't have forged pistons but still have strong internals,in fact some have better flowing heads than the s3 but the weak con-rods are still present.
  12. 2pac
    2pac E3 APC
    55
    [ QUOTE ]
    [/ QUOTE ]
    Nice one, some good info there. Good to no if I eva want more power it will take it
  13. HTC
    HTC Active Member
    3,428
    9
    Yeah sorry guys. Was talking about K03.
  14. Dean_T
    Dean_T Active Member
    645
    139
    43
    i think my A3T peaks around 1.25bar but not 100% sure on that
  15. PaulRS3
    1,218
    150
    not standard it shouldnt.
    S3 boost is only 0.9 bar standard... with the bigger K04 turbo.
  16. jimboA3
    jimboA3 Member
    336
    my a3 quattro is peking at 1.5 bar - sustaining 1.25.
  17. Dean_T
    645
    139
    43
    [ QUOTE ]
    [/ QUOTE ]
    thats right, its been remapped, no idea what it was as standard though /ubbthreads/images/graemlins/frown.gif
  18. PaulRS3
    1,218
    150
    remapped is the way. /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/groovy.gif
