1.8T BAM/AMK Crankcase Breather Pipe
*P3nfold* Apr 19, 2013
  1. *P3nfold*
    *P3nfold* Member
    368
    15
    Only been on the car a short while, decided to go catch can so this is for sale. I will give it a good clean before posting it.
    Unlike the standard rubber OEM hoses which deteriate over time our hoses are constructed using a high quality silicone Polyester or Nomex compound. They are further reinforced with a polyester layer to provide a more rigid structure. This item replaces the Weak OEM black rubber PCV breather pipe with high Quality reinforced Silicon item.
    You are getting a replacement silicone item for less than the OEM rubber pipe that will eventually fail again. These pipes are notorious for failing on every SEAT LEON CUPRA R and S3 20VT engines. The pipe goes on the side of your current rocker cover and is used for crankcase ventilation
