1.8T AVJ battery drain
Alan H May 2, 2011
  1. Alan H
    Alan H Need a V8 or Bi-Turbo.......
    457
    Well, I've found out what drained the battery the other day I think.
    I fell asleep on the sofa last night, woke at about 02:30. And I thought I'd stick my head through the curtains to have a nosey before retiring for the night.
    I looked out and I could see red reflections in the windows of the houses opposite.
    I went outside and found my brake lights were on!!!
    Opened the car, and touched the brake pedal with my foot and they went off...
    Think it needs a new brake light switch?
  2. Mike B
    Mike B Well-Known Member
    1,101
    40
    thats a new one.Perhaps it will free up with some WD
  3. quattrojames
    14,050
    578
  4. Alan H
    457
  5. quattrojames
    14,050
    578
    I think the brake light circuit is live with the ignition off on our cars? If so then if the switch is shorting and completing the circuit all the time it will do yes.
  6. Alan H
    457
    I didn't realise that. But if that's correct then they will operate without the ignition being on..
    It's an intermittent problem though, it happened during the really cold weather a couple of months back (and I put it down to the weather)
    Trip to Audi on Saturday morning.....
  7. Mike B
    1,101
    40
    I would still try freeing it first whats to lose?
  8. AndyMac
    9,832
    46
    And definately don't take it to Audi!
  9. Alan H
    457
    I'll give it a go with some silicone spray tomorrow. The trouble is because it's intermittent I won't be sure whether it's worked or not....
    I won't take it to Audi, just get the bit from Audi... What am I? Made of money!!!! lol
  10. Alan H
    457
    Gave the switch a spray, but it made no difference.
    The switch that was supplied was different to the one that was fitted. It works, but I'll upload a pic from my phone momentarily.
  11. Alan H
    457
    The one that was fitted was like the one in the PDF file on this thread, but the one I got is like thi:
    As long as it works I don't mind. I would assume the original part may have been superceded.
  12. quattrojames
    14,050
    578
    Don't forget to add the part number ;)
  13. Alan H
    457
    Doh!!
    The invoice has got: U1K2 945 511 RD W A-A061 SWITCH
  14. quattrojames
    14,050
    578
    Thanks, I'm not aware of them being a serviceable part (unless you're a microscopic electrician!) I hope it solves it.
  15. quattrojames
    14,050
    578
    Thats an unusual part number, did it come from Audi?
  16. Alan H
    457
    It did, Wolverhampton Audi. It's got the VW logo on it.
  17. quattrojames
    14,050
    578
    Probably just a common part across the whole range then, thanks.
  18. S3 GAZ
    S3 GAZ Member
    381
    17
    When I changed my brake switch I got the one u got too. It was totally different to the one in the car. But it works absoloutley fine
  19. Alan H
    457
    From what S3 GAZ says it looks that way doesn't it.
    That's put my mind at rest a bit.
  20. S3 GAZ
    S3 GAZ Member
    381
    17
    yeh no need to worry. I bought my part from Audi Braehead
  21. Alan H
    457
    I think it may have worked, got up this morning and the brake lights aren't on. (it's worked or the battery is very flat)lol
    Will see in a moment or two when I go out to the car to go to work.
  22. Alan H
    457
    Well it started. So let's see if it keeps it up.
