1.8T 20V Con Rod Failures
Welly Oct 8, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    127
  2. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    After our chat the other evening this is my next job. :thumbsup:
  3. Welly
    10,696
    127
    A wise decision.... It just shows that in reality, it's not if. But when.
  4. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
    have there been instances of rod failure on stage 1 maps or even just standard engines?
  5. Welly
    10,696
    127
  6. Alex C
    3,261
    357
    ah, yeah i remember you had that failure, didnt realise you were stage 1. Do you think its too conservative to have new rods beofre going stage 1?
  7. Welly
    10,696
    127
    I don't think it's conservative to have new rods at any time. IMO 1.8T rods are gash.
  8. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Its on the massive list of things to do. Lol
  9. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    ahh man! i hate reading stuff like this it makes me think theyre gonna go now everytime i drive my car :(
  10. Welly
    10,696
    127
    You should be OK dude to be fair, what the output on your A3? Bear in mind that the S3s have the same rods as you (presuming you're an AGUer) and run more power standard....
  11. jojo
    28,856
    3,516
    You also have to put it on the choice of stage1 map also, all this 'low down grunt' with 'push in the back' torque is bad for the rods.
  12. DaveA3
    2,370
    15
    185bhp with boost leaks lol should be about 190bhp think it was something like 214 lb/ft torques need to double check that. yeh im on an AGU.
    cheers man thats good to hear :D
  13. Welly
    10,696
    127
    You should be A OK mate, I wouldn't lose sleep.
  14. Welly
    10,696
    127
    Agreed, finger pointing towards REVO maps here....lol.
  15. superkarl
    superkarl MAN OF STEEL
    9,428
    2,397
    is a revo map a dangerous one then on standard internals?
  16. Welly
    10,696
    127
    No, not dangerous. However, REVO maps are known for their aggressive delivery by all. Much less progressive than other maps, and that's due to the torque production. As Jo said, early and harsh torque isn't the best for the rods.
    Many people are using, and have used, REVO maps for a long time with no issues. But out of the generic maps available, I would say they are the most likely to cause issues. That's not to say will.
  17. superkarl
    9,428
    2,397
    i see what you mean. id want a more progressive map anyway. my car is off the road soon and after the wear and tear stuff i've got to do, rods are my number 1 before i get a map. better safe than sorry
  18. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    People need to stop thinking there engines are going to fall apart any minute lol. Ye rods fall but its a very small minority that do and they tend to be running quite a bit more torque and power than the standard engine spec.
    Im doing a con rod FEA assignment in uni now and wanted to do it on a S3 rod but havent got the dimensions on one to measure accurately.
    Nathan
  19. Alex C
    3,261
    357
    well perhaps if i change my rods because im too scared to go without doing it you could have my OEM rod to do your FEM :moa:
  20. S3 Nattie
    1,599
    Lol thats sounds like a good idea to me.
    Nathan
  21. tompearson
    tompearson It's all in bits
    219
    I have some in my garage - what measurements do you want? (or are you meaning you want to test to destruction?)
    Also have some IE and Brute ones if you need a comparison.
  22. S3 Nattie
    1,599
    I would need the following;
    Length from top to bottom
    Width of the rod
    Diameter of the gudgeon pin and bearing but I think I have just found them on the net.
    Distance from the gudgeon pin to the outer side of the rod.
    The radius of the rod stem where it meets the gudgeon pin and the bear
    Diameter of the stem just after the radius's top and bottom
    The radius's, diameters and lengths of the intersect in the rod and how far into the rod it is to get a section view of the rod.
    Would also need the measurement around the bearing but unsure how to describe them.
    Its pretty easy to measure the rod but its then working out what happening within the engine such as cylinder pressure at certain rpm's, air/fuel mass within the cylinders, the acceleration and resistant forces acting on the rod, tension and compression forces, vertical and horizontal force acting on the rod and bending monents/loads etc to get a full understanding of what the rod if being exerted too.
    Im actually doing my final year project on My S3 and might start a thread as it should contain very useful info.
    Does anyone know what the factor of safety is on a S3 rod.
    If I had one I would measure one up myself. I might be able to get one in the from a vag garage I know by me. Mainly have jags and Ford rods in uni.
    Nathan
  23. finesse
    finesse Active Member
    2,805
    Nathan, what package are you using for analysis? Ansys, Abacus, Catia, Solidworks?
    I would guess a safety factor of 1.5
  24. S3 Nattie
    1,599
    We have got solidworks but I dont use it, heard its quite user friendly. Were using NX now and I think NX7 is being installed over the weekend, think thats the latest NX verison you can get. NX is very good but like most software, it likes to freeze and run very slowly sometimes.
    Nathan
  25. Essflee
    Essflee Well-Known Member
    2,142
    66
    If I listened to every horror story I'd heard about S3's etc, I'd never have got a remap and would of sold it a long time ago... Lol
  26. superkarl
    9,428
    2,397
    well you hear the horror stories, and then the cost and pain in the ass of sorting it out. so if you can prevent it, you may aswell. i know i dont want to be buyin new engines. especially when your car has done as many miles as mine. Im over modding for power, i want to increase the longetivity of my car now, because i dont wana sell, so il keep till it proper dies. Rods just come into the equation when prolonging the life of it. its just a bonus that i won't ever need to worry about bending one. unless one day i have a spike of 500lbsft of torque or somethin crazy like that, which will never happen.
  27. S3 Nattie
    1,599
    Lol Im with you there. Everyone on this forum will try there best to give everyone else the best advise as possible and 99% of the time its very good advise. But theres got to come a point where you say its not realistic or cost efficient to do so for YOUR situation.
    Nathan
  28. finesse
    2,805
    NX makes me sick, but it is powerful.
    I have a conrod I modelled here if you want......
  29. S3 Nattie
    1,599
    Lol ye NX is very powerful software and it nearly literally made me sick last year when I was doing some work and it decided it wanted to just randomly freeze and shut off and I never saved any of my work. Good job I have a very understand lecturer.
    You have got a actually working model of a S3 con rod. That would be interesting to have a look at.
    Nathan
  30. finesse
    2,805
    Not S3, just a generic one I used for analysis and mold and manufacturing in NX
    NX:Flush::Flush:
  31. Welly
    10,696
    127
    Look, bottom line, I thought it was useful info for people.
    It doesn't happen to everyone, but it DID happen to me.
    If I can help people avoid the drama and cost that I went through, then I will bloody well try! lol.
  32. finesse
    2,805
    Totally agree, it is a job which should be on every enthusiasts list.
    It's not appealing because it doesn't provide epic 5bhp gain like an air filter or stop better like 8 pot brakes
  33. Alex C
    3,261
    357
    how much would you be looking at paying for the rods and fitting?
  34. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I dont think you will have a lot of change out of a grand with new shells, oil, belt ,gaskets etc.
    I agree with welly, he is not scaremongering, just giving good info that may or may-not be heeded, depending on your application......
  35. finesse
    2,805
  36. Welly
    10,696
    127
  37. Alex C
    3,261
    357
    thanks guys, im not gonna rush out and do it, but food for thought, cheers Welly!
  38. S3 Nattie
    1,599
    I agree with you, thats what forums are for, giving members advise to benefit them or fill them in with info.
    Just wondering, what are the torques for the shell.
    Nathan
  39. drfeelgood
    drfeelgood Member
    225
    This is the reason why i wont do anything to the engine.
  40. Welly
    10,696
    127
    lol, and who could blame you dude. Tits and wheels are nothing but trouble.
