1.8 turbo help
jay1601 Sep 17, 2010
  1. jay1601
    jay1601 Well-Known Member
    1,311
    57
    i got a 1.8T today, i've done a search but can't find a quide how to fit a boost gauge. anyone know where i can get a quide ?
    thanks for any help Jay
  2. murran
    murran Well-Known Member
    1,545
    39
    what sort of guage?
    vac/pressure sensing lines/pipe are usually teed into the fuel pressure reg pipe.
  3. jay1601
    1,311
    57
    i would like to fit a boost gauge. would like to know what sort of PSI its full obbst is before i start tuning.
    thanks Jay
  4. <tuffty/>
    20,896
    3,705
    Use a t-piece to t'ee the vacuum pipe for the gauge from the fuel pressure regulator... if your gauge comes with the clear soft pvc type pipe to connect it, bin it and buy some silicon vacuum pipe instead... Forge or ebay for that...
    Route it into the car either through the grommet thats to the right (as you look into the engine bay) of the pollen filter (under the scuttle cover on the right hand side) or by drilling a hole and using a grommet in the plastic cover for where the wiring comes into the engine bay under the scuttle cover on the drivers side... you will need to remove the wiper blades for this (13mm nut holding them on)
    Fitment for the gauge is your personal choice, gauge pod screwed wherever you want to, vent pod that replaces the drivers side vent, pillar pod.... there isn't a specific A3 pillar pod that I have been able to find but there are universal ones that can be modded... there is a write up in my build thread (link in my sig) and there are a few other examples on what people have done... just search for 'boost gauge' and have a flick through... there are a few results to trawl through but then thats the fun....
  5. jay1601
    1,311
    57
    cheers mate :)
    sorry to be a pain you wouldn't have a pic where i should T into do you ?
    thanks Jay
  6. <tuffty/>
    20,896
    3,705
  7. jay1601
    1,311
    57
    cheers mate, your the best :)
    thanks Jay
  8. Chris_38
    Chris_38 Member
    33
  9. Tim_Attard
    Tim_Attard Active Member
    473
    44
    i would assume red is live, black is ground and orange is to the sensor
  10. jay1601
    1,311
    57
    epic thread bump
  11. Chris_38
    Chris_38 Member
    33
    We're do I attach the wires to j never got a fitment guide
  12. jay1601
    1,311
    57
    black will be earth
    red will be power source
    orange will be prob be for a dimmer (guessing its a mechanical gauge)
  13. Jersey
    Jersey Member
    114
    13
    Just after some little help,
    Ive looked everywhere for an exact picture of where to run my boost gauge piping to the front left under the scuttle panel. I have seen the black box with lots of wiring and a single wire which i think is the bonnet catch cable. Where do i drill a hole? it seems risky putting one next to the bonnet catch because the way the water would flow off.
    Sorry for such a **** question, but its annoying me where to put it and don't want to take it to a garage now i have got this far.
    Cheers,
    J
  14. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,782
    615
    I just drilled a hole very gently about a inch up from the bottom left (looking from the bumper towards the scuttle) and ran it through there, done it about 6 months ago and never had any issues with water getting through the hole, keep meaning to get some sealant on it just in case, but just haven't got around to it yet. I did use a 5.5mm drill for 6mm od hose though so it was quite a tight fit to pull it through.
    If you are nice and gentle with the drill you should be able to see a bit of light from inside the car to make sure you don't have any issues with drilling through cables inside the car.
  15. Jersey
    Jersey Member
    114
    13
    thanks Lavis for your quick reply,
    So just to make sure, you drilled the hole next to where the other cable (bonnet cable) not higher up. This then came straight into the air duct in the car?
    cheers,
    j
  16. Lavis89
    1,782
    615
    no it didn't go straight into the air duct, i had to take the bottom part of my dash off and feed it in through a hole in the side of the duct.
    just googled a picture and found this
    WHOOPS! did not know that was there, i thought it was a straight through pannel to inside the car. good thing im not a sparky! but i remembered i drilled the hole to the top left of the box (remember thinking it would be less likely to be under water up there) so must have missed any wires. going to have to strip it down next week just to make sure. obviously didn't do enough research on this one!
    i've actually drilled straight through that connector box. definitely going to seal it up now
  17. Jersey
    Jersey Member
    114
    13
    thanks lavis and i hope it all okay.
    Has anyone else done this or something else? drilling on the left hand side of the box?
    cheers,
    j
