1.8 t remap. & thermostat location
veedub89 Mar 18, 2013
  1. veedub89
    veedub89 New Member
    14
    hi guys, 2 questions:
    1. is it possible/ worth a remap for economy on a 1.8t if so how much should it cost?
    2. can someone point me in the right direction of the thermostat, as my heating dosnt get very warm
    cheers
  2. Ian2012
    Ian2012 Active Member
    473
    29
    If i were looking for a remap i would use MRC, all depends on where you are in the country. Thermostat location is underneath the inlet manifold, bit of twat to get to as you have to remove a load of bits to gain access, still not the worst job in the world to do
  3. Broken Byzan
    13,237
    465
    I wouldn't use MRC, they are not so good on 1.8t's, either Badge5 or Rtech are at the forfront of 20vt tuning atm.
    Stat is located in the plastic housing secured with 2 x 10mm headed bolts on the end of the rad lower pipe, dead easy from underneath
