1.8 SE intermittent starting issue
easytease Feb 1, 2006
  1. easytease
    easytease cheesypeas
    433
    every now and again the car is very slugish to start.
    when started from cold in the morning she's fine not a problem, but lately when shes warm/hot and i try to start her she struggles to start. the reves reach about 800 but a quick blip on the go pedal seems to rectify the low revs.
    any ideas? shes a 1999 on 53k (belt and waterpump being done in april!)
  2. FezzR
    FezzR Member
    86
    coolant temp sensor is a good place to start, the gauge reading is not a good representaion as the ecu and gauge run on a different circuit within the same sensor
  3. easytease
    433
    coolant runs up to the 90 and sticks there nomatter if im doing motorway speeds or stuck in traffic.
    anyone in surrey/hampshire got vagcom and wanna gimmie a hand?
  4. joost
    joost Active Member
    1,169
    like Fezz says, they are are actually on different circuits. IIRC, there's actually 2 sensors at the back of the engine - one is for the gauge, other for the ecu. vagcom should show up any probs though.
    Mine plays up occasionally when warm starting, seems to struggle to start then cuts out and needs a bit of throttle to get it going again. This led me to think I was having probs with my temp sensor (albeit on a '95 1.8) as mine also seems to be running quite rich. Had it plugged into vagcom courtesy of FactionOne this weekend and no faults showed up about it so back to square one for me!!
  5. Willod
    Willod New Member
    My first post and i will be paying close attention to this thread since im having exactly the same problem.
    Car starts fine from cold but from time to time starting from warm it doesn't seem to turn over enough and stalls then requiring a longer turn over to get it started. Yes and mine is also running rich.
    96 1.8 with 74000 miles on the clock
  6. easytease
    433
    hmm coming to think about it, mines prolly running a bit rich too. ill have to get a vag com sorted /ubbthreads/images/graemlins/laugh.gif
  7. joost
    joost Active Member
    1,169
    Exactly the same as mine Willod, have to crank it a bit longer and give it a little nudge on the pedal. Runs fine then for a bit.
    Mine's got 122k on the clock though - d'ya think it might be time for a new 'un?
  8. easytease
    433
    new what? car or temp sender?
    if its unlikely to not start then i'll wait till the service in april, otherwise ill get a new one and fit it at the weekend
  9. FezzR
    FezzR Member
    86
    the temp sensor wont always show a fault.
    a fault will only be logged if the sensor gives a faulty signal, it could be reading 90 degrees when its actually -4, the ecu doesnt know different so just sets fuel for warm start.
    using vagcom read measuring block 1 or 2 depending on engine and it will give a temp reading this is coolant, see if its right at cold and at high temp.
    Also A4 fuel pumps tend to get weak getting hot and cold start problems, this is usually V6 models though apparently
  10. joost
    joost Active Member
    1,169
    New car Easy, use it as an excuse mate! Go out for a new temp sensor, come back with a car! /ubbthreads/images/graemlins/smirk.gif
    Fezz, that would explain why there were no fault codes for the sensor on vagcom when I had it plugged in at the weekend. Could still mean it's a quick fix though. /ubbthreads/images/graemlins/grin.gif
  11. FezzR
    FezzR Member
    86
    ive got the same problem with my V6 but i just dont wanna shell out for a fuel pump
  12. Broken Byzan
    13,244
    468
    I would go for a temp sensor too mate, make sure you get an OEM one tho, apparently the copies are known to be poor IIRC
