1.8 Cylinder head bolts removal tool
B5NUT Jul 4, 2010
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,677
    634
    I need to remove the cylinder head, so need the correct tool to remove the head bolts. I just want the one tool, as I don't plan to remove any other cylinder heads, also must be 1/2" drive. I've seen one snap-on tool on ebay for just over £21, is that a good price or can I get one from halfords, eurocarparts etc?
  2. tux
    tux Member
    89
    Is it the same M9/10 Polydrive (Ribe type) as the V6 engines? If yes the cheapest I could find was about £16 delivered on eBay. Didn't want to spend more than I had to as I will likely only use it on the one head job.
    If it is the polydrive type, a little tip is to tap it into the head bolts with a small hammer before trying to undo them or it slips and chews the bolt heads up really quickly.
    This is the one I think
    http://cgi.ebay.co.uk/VW-Audi-Skoda...t=UK_Hand_Tools_Equipment&hash=item335e3492fb
  3. B5NUT
    3,677
    634
    That is my consern, that's why I want to make sure I get the correct one.
  4. tux
    tux Member
    89
    The reason it needs tapping home, is that the bolt head, by its design has a bit of a cup effect going on and is invariably full of oil. Pushing the tool into the bolt head doesn't displace the oil and it only goes in 1/4 to 1/2 way. A gentle tap helps to squeeze out the oil and seat it fully home. :sm4:
  5. B5NUT
    3,677
    634
    I Understand that, my consern is that possible **** in the bolt not just excess oil and the use of a cr@p tool & 15 years with being in the same possition = one stripped head bolt......
  6. aragorn
    17,956
    701
  7. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    unless you plan on whipping off heads all the time it is a £15-20 bit of jewelry that will sit in your tool box for the next few years.
    I have one if you just need to borrow one, not planning on removing heads anytime soon.
    works a treat and is the VAG specific one rather than a generic one
  8. B5NUT
    3,677
    634
    Thanks for that, will let you know.
