1.6 FSI Engine...is it that bad?
AK Aug 7, 2008
  1. AK
    AK New Member
    Hi all,
    Been looking for a Diesel 2.0 TDI to find either ones with high mileage or early models (according to my budget)
    Having read a few posts on here, it appears that these engines do like to drink a lot of oil.
    I have also been looking at 1.6 FSI's but not sure what they are like - performance and reliability wise.
    There has been a few comments on here about the 1.6 engine being sluggish and not worth it but what about the 1.6 FSI?
  2. golf
    golf ***** rent boy VCDS Map User
    1,556
    It's perfectly adequate in town driving and short trips, but if it's thrills you're after or easy overtaking the diesel will be miles better. Will still be dull, but the torque will make driving on the motorway less of an ordeal.
    They're still very unrefined compared to the 1.6. The FSI variant has 13bhp more and is more economical, but will cost more obviously. I think the Road Tax will be cheaper as well, but if it were me I'd avoid the base models of any car as they will be poverty spec.
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    Apparently you need to use the 98 ron stuff to utilise that additional horsepower - otherwise you just end up with the same 102hp as the non-FSI 1.6 engine.
    That's what I was told by my dealer when the 8P A3 came out at first and i was enquiring about what the difference was between the fsi and non-fsi. I couldn't understand why they would make two different versions of the same engine. Don't think the 1.6fsi model ever sold in great numbers.
    just to pick you up on your "poverty spec on the base model" comment - presumably by base model you mean non-sport, non-se as opposed to the 1.6. Aren't the different trim levels all the same spec except for the engine?
  4. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    How about a 1.9 TDI ?
    They're a bit dearer than the 1.6 but better IMO
  5. biggiep
    biggiep Member
    156
    Even in standard guise I don't think you could say the 2.0TDi is boring? Its not lightning quick buy any stretch but its entertaining and punchy and a hell of a lot better than most stuff on the road.
    Not expensive to re-map and get a genuinly entertaining car for the economy/price.
    Maybe were confusing it with the 105 1.9TDi ?
  6. Amchlolor
    Amchlolor Active Member
    5,604
    Yes, the 1.6Fsi is that bad.
    As others have said, even the 1.9tdi is better.
    We have one of each in the fleet, I drive both semi-regularly.
