1.6 2003 a3 shakey on idle
h18srw Jun 2, 2012
  1. h18srw
    h18srw New Member
    9
    ok Audi gurus, still fairly new to the world of Audi.
    my 2003 1.6 is a bit shakey when shes in idle mode.
    recently through MOT, i had 2 breather pipes fitted due to holes but there has been no improvement.
    checked the internet and have ruled out clutch as it does not disappear when I depress it.
    anybody any ideas, audi want to charge me £80 to plug it in and run diagnostics.
    is there any way it could be the exhaust system??
    doing my head in as this wee car is immaculate for a 2003 model, 75k, timing kit installed etc
  2. Dannyhall
    Dannyhall Member
    213
    Not sure on the improvements needed to make it better, just know it's called eratic idle and it's very common
  3. h18srw
    h18srw New Member
    9
    seems crazy for such a solid wee car, makes it feel like she is going to cut out
  4. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Where abouts are you? I'm sure a forum member could do a scan on your car for a couple of beer tokens?
  5. h18srw
    h18srw New Member
    9
    may not be so easy, Im in NI.
  6. a6_chris
    1,883
    160
    Guessed that after seeing 'she's in idle mode'
    Where abouts, I might be able to help you out?
  7. a6_chris
    1,883
    160
    Edit - wrong thread lol
  8. h18srw
    h18srw New Member
    9
    belfast
  9. a6_chris
    1,883
    160
    I'm in Belfast most days but I work nights - there's an Audi Specialist called Walsh Motors down the M1 who will be far far cheaper than Audi - if you can wait I'm up next weekend and can bring my laptop and vcds.
  10. MTRL
    MTRL Split Grill!
    459
    52
    Check your engine mounts. Mine started doing this a few weeks after I had my cambelt changed. Turns out an engine mount was not put back together properlly and one side of the engine dropped through the bottom of the car.
    Its fine now they have been replaced.
  11. moag
    moag she's no d-turbo
    821
    35
    I'm based in Bangor and have VCDS software, drop me a message if you need the car scanned!
  12. h18srw
    h18srw New Member
    9
    where abouts in bangor
  13. h18srw
    h18srw New Member
    9
    i asked my mechainc about this over the phone and he said it wouldnt be usual for an 2003 to need done already. i may need him to take another look at that one, I take it he could spot this from a visual check
