1.4 TFSI noise on cold start! not related to The Turbo rattle thread!!
First Ever Audi Oct 2, 2013
  1. First Ever Audi
    First Ever Audi Active Member
    271
    72
    Time to kick this one into touch seeing as the Turbo Actuator rod RATTLE thread is all but dead. Since day 1, my car has made a weird noise on startup....and only on startup, when the STOP START kicks in later! the noise isn't there so I'm presuming its normal. I can only describe it as a kind of howl, like a cartoon cat yawning???? It doesn't sound mechanical but it is identical each and every time. Im sure there was a similar thread with a sound bite and they had an identical noise.....this happens regardless of outside temp or AC on or off.....thanks in advance!!!
  2. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,941
    1,702
    Hi, could it be the electric fuel pump priming up? The fuel system does run quite a high pressure...
    First Ever Audi likes this.
  3. Schizophonic
    Schizophonic Well-Known Member
    868
    437
    I get this noise too but it's certainly isn't anything to do with the rattle problem.
  4. Pganders
    Pganders Member
    49
    I have the same noise you refer to. The noise happens only once on a cold start first thing or if the car has been sitting for an extended period of several hours which would suggest, as cuke2u says, that something is having to be primed.
    It would be good to know that it is just a "quirk" of the engine rather than anything untoward.
    Wondering does it just occur on the 1.4 (122) or does it happen on the other petrols??
  5. TFSI
    TFSI Born to Fish
    540
    52
    My present and previous 1.4's did this if it's the same noise.
    On cold start occasionally and lasts for 20-30 seconds only. RPM is higher than normal low idle, you can hear the turbo whistling and a noisier exhaust as well. Its on choke (excess fuel) but not gauranteed to do it even on a cold frosty morning from previous experience.
    Sounds damn well tho. like it's got loads of litres hiding away under the bonnet instead of a baby 1.4
  6. Superman23
    Superman23 New Member
    25
    I don't think it is the same noise, mine does the start-up whine but only for about 2-3 seconds and I have a 1.8TFSI.
  7. karlabdool
    karlabdool Member
    159
    19
  8. Schizophonic
    868
    437
  9. First Ever Audi
    271
    72
  10. mjcourtney
    mjcourtney Well-Known Member Team Mythos Audi A4 Audi Avant Owner Group S-line owners group TDi
    1,687
    526
    Identical sound to mine too. But i'm not worried, it still sounds like a pump priming to me.
  11. wimpy
    wimpy New Member
    Is this confirmed as nothing to worry about? My new 1.4 A3 has the same noise on startup under the same conditions.
    pburv likes this.
  12. pburv
    pburv Well-Known Member Team Glacier Gold Supporter Audi S3 quattro saloon DSG
    5,188
    10,855
    Yep. My S3 has this noise on start up .It's the fuel pump priming ....Nothing to worry about..:friends:
    If you are concerned take it to your dealer and ask them to look at it...:shrug:
  13. wimpy
    wimpy New Member
    Thanks for your response. I noticed that if I gave it some gas, the noise gets more pronounced. Expected?
    pburv likes this.
  14. pburv
    5,188
    10,855
    To be honest I only notice the sort of 'whaling' sound when I start the car.After that I don't hear any more noise...
    Maybe as a precaution you should get it booked in at the dealers..I suspect though that nothing is at fault and that you shouldn't worry.Either way your car is new and is covered by warranty so if it is faulty it will get sorted...:friends:
