Hi all,
New to the forum so apologies if I have screwed something up / posted in the wrong location.
I was wondering if someone had any suggestions on how to cure the following; I have a 1.2A drain with the ignition off which is chomping through the battery within a couple of days parked. It also struggles to start if both the AC and radio are running, even if it has been driven earlier that day. I have gone through pulling fuses and found the following:
Thanks in advance!
- 0.6A background (can't get rid of it regardless of fuses pulled)
- 0.4A reduction if instrument cluster fuse removed (i.e. 0.8A background drain still)
- 0.1A reduction if interior light / reading light fuse removed
- 0.1A heating & AC control unit fuse removed
Thanks in advance!
