09 White Cluster/DIS fitted to 04 8P
NHN Mar 3, 2009
  1. fizz
    fizz Member
    264
    Spoke to Ben who says that at the moment he can only code & correct mileage on brand new 09 clusters not ones that have been coded previously.
  2. NHN
    29,299
    1,702
    As already advised to number of people, goto audi who will do it in 30 minutes tops, I had mine both done at audi, just dont have the time to feck about with anyone else & for £40 couldnt ask for better tbh.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    Meant to say N, RE the fuel guage issue, when I tested my cluster it did give a warning regarding the fuel guage not working so I need wire/pump though yet to look at the pump under the seat to see whats all needing done. You don't know the repair wire numbers LOL??
    Mine is a 53 plate - I Believe 09/03 made though - for reference to anybody else planning mod.
  4. NHN
    29,299
    1,702
    Pass mate you'd have to check etka & route through that way as I didnt need to add the wire as mine was prewired as just before facelift & wire changes so its kinda a hybrid loom for me lol.
  5. Khufu
    5,704
    31
    Hey, its ok I'll get it no problem, was just kiddin'. My wiring is different too as its an FSi - its wired via the J538 module.
  6. waqi
    waqi Member
    150
    Very sorry Nigel, my stupid moment!
    Wanting to fit the same 09 cluster with DIS
    My car is a 54 plate sportback 2.0 tdi basic - it has no DIS. The production date is 13/11/2004, so can't be sure about the pump/wire! I will check for the wire tomorrow but I've got my VIN number, how do I check for pump. I've got elsawin on my pc if that helps
    Does anyone have a clue about what extra work I will need due to not having DIS?
  7. Khufu
    5,704
    31
    A new stalk to control the DIS for starters LOL. You could find that you will need to fit the wires to the cluster from the new stalk, other sensors like washer bottle, bulbs out etc or you will get a lot of warning errors. All is possible as you have elsa to compare wiring but it might be a bit of work.
    If you remove the rear seat bench and unscrew the cover over the fuel pump on top of the tank you will see the 5 pin multiplug, if all 5 wires are connected your good to go, if pin 4 isn't connected you will need a bit more work.
    I'm going to study my fuel pump wiring tomorrow (petrol) to see what i can work out LOL
  8. NHN
    29,299
    1,702
    You would need to check the pump part number aswell as the wiring, as I had 5 wires but only used 4 so had to fit a new pump anyway, but K has advised what I would of anyway so kudos to him.
    100% you will need wiring schematics to do this conversion, could always plug in new one & see what errors you get as I'm sure of top of head the can & power wires are same, subject to checking you understand, then you can see what it isnt getting comms on & start working on the wiring.
  9. waqi
    waqi Member
    150
    To be honest mate, too much hassle for a non DIS car. Definitely worth looking at Patrick's 09 cluster in classifieds if you've already got DIS!
  10. NHN
    29,299
    1,702
    It isnt really when you consider the added features you get, but for me its a challenge to say it can be done, nothings impossible, just time, money & patients, yours is harder than most but totally possible, if was me I'd relish the challenge mate.
  11. Khufu
    5,704
    31
    had a look today. Five pins on my pump into multiplug leading to 5 wires into the module (FSi only) then out to 8 pins but only 7 wires in the loom - number 8 is the missing one. Will run wire from pin 8 to 25 on the cluster & see if it works. If not, will keep eyes open for pump.
    NHN, did your pump have 5 pins too but didnt work (I know you have diesel)?
  12. NHN
    29,299
    1,702
    Yes my old pump had 5 pins but obviously one wasnt used internally & I suspect it was placed to give the connector stability & to use as a centered fitment for the loom plug, if that makes sense.
  13. Khufu
    5,704
    31
    sadly it does LOL. Still havent got chance to check if mine is dead too. Roll on warmer weather & light nights!
  14. NHN
    29,299
    1,702
    Torches are wonderful things you know....................................
  15. Khufu
    5,704
    31
    Thats how I broke the purple latch on the blue 32 pin connector for the cluster LOL.
    Got my wires sussed any how, just keeping eyes open for pump. Might have more luck getting Golf one if i could cross reference parts LOL??
  16. fizz
    fizz Member
    264
    Will be getting a white cluster in the next few days, gona have to make the 160 mile round trip to stoke audi though to get it coded as my local dealers don't have a clue on how to code :(
  17. NHN
    29,299
    1,702
    Huuuuuhhh hurrrrrmmmmmmmm
  18. Khufu
    5,704
    31
    master technician on holiday???? Certainly doesnt inspire confidence!
  19. fizz
    fizz Member
    264
    lol, dont think they have one tbh.
    Got the cluster sitting here but working over the weekend. Might give a few other dealers nearer to me a call and see what they say before going all the way to Stoke.
    Does the dealer have to pair to car and keys or can we do the keys ourselves with VCDS? Just want to know whats involved so that I can tell them what needs doing.
  20. fizz
    fizz Member
    264
    Also, not sure if anyones tried this yet but does anybody know if the immobilizer part inside the DIS is separate and interchangable with the old DIS, therefore avoiding the need to get it coded?
  21. wesley
    wesley Giac Extreme+!! Lovin it
    350
    23
    Where in the country are you mate?
  22. Khufu
    5,704
    31
    The immobilizer chip is soldered to the pcb board so it wont be changeable. You could use VCDS if you had your SKC but thats impossible to get on our age of cars without expensive software/leads like vagcommander etc.
  23. fizz
    fizz Member
    264
    Blackburn mate
  24. fizz
    fizz Member
    264
    Im sure a hot air station would do the job, hmmm. Shame bout the SKC or could probram the keys myself. Looks like its going to be trip to the dealers to code. I'll also dig out the old hot air station and experiment removing the chip off the old one :)
  25. NHN
    29,299
    1,702
    Its also got different components on the pcb so forget that idea.
  26. fizz
    fizz Member
    264
    Got the new cluster coded by Stoke Audi today. Looks great, definitely worth the trouble. Thanks to NHN for the advice & N8 for helping out by providing a copy of his invoice as otherwise would have been charged an hours labout for 30 mins work.
  27. Khufu
    5,704
    31
    That's handy to know, im still needing to get another fuel pump 1st. I may need a copy too LOL
  28. Maga84
    Maga84 New Member
    Hallo NHN, are Italian boy who carried out thanks to your guide, changing the cluster from red to white.
    Now I'm still as in your case the error of the brakes.
    I need to understand the coding you have done to remove the problem of the ABS / ESP / ASR.
    I'd like to know the encoding of the ABS brake control unit you have.
    My car is A3 8P 2004 2.0 TDI
    ByeCristian
  29. fizz
    fizz Member
    264
    What you need to do is go into the controller 03 (ABS), login with security code presented in vcds and just go into the basic setting for the Longitudinal sensor, Lateral Acceleration sensor & Brake Pressure Sensor. This will clear your errors.
  30. NHN
    29,299
    1,702
    nah Fizz mate, thats not what he's referring to, there's an adaptation you have to go into to set the brake system on the car, please read my original post as its all in there not repeating something thats already written very clearly & plain english, dont be lazy cristian.
  31. Maga84
    Maga84 New Member
    You're right, I had followed the guide:
    Enters the channel 37 of the cluster and then sets 11 as the value.
    Except that the engine is running I did not enter the password that logically Vag clearly signaled me!
    Now I set the value from 1 to 11 for 2wd and everything worked!! :rockwoot:
    Great!
    Congratulations for the explanation, excellent in all!!!
    Just one question, but the miles do you have them set in Audi?
    Thank you very much
    Cristian
  32. NHN
    29,299
    1,702
    Glad you have resolved this, but again cristian read the 1st post it also mentions about the mileage setting with old/new clusters, seriously mate please read instead of browsing, I dont mind helping you but only after reading it thoroughly as afaik it has all the info you've requested.
  33. Maga84
    Maga84 New Member
    I read that you do that if the specification is less than 100 km can be set, otherwise it is maintained with the miles marked.
    But I felt that instead in Audi can, if I hear I can inform you as soon as possible.
  34. NHN
    29,299
    1,702
    If its new with less than 100km's on it then audi can change mileage, if over 100km's then audi cant change mileage.
    You can ask other people who can adjust mileage to change it for you at any mileage.
  35. Khufu
    5,704
    31
    Pulled my pump out today to check the wiring. There is no pin on the actual sender that isn't connected to anything that could be connected to the multiplug so def need new sender. Getting a replacement seems to be a part number minefield tho it looks like the passat, Golf Mk5 share same parts.
  36. tcardio
    tcardio Well-Known Member
    962
    276
    Looking to change out my 09 A3 cluster for 09 S3 cluster. Any technical advice ?
  37. NHN
    29,299
    1,702
    Yeah read the thread then ask any more queries!!
  38. tcardio
    962
    276
    Wow! Guess I need to move to Europe to ask for help. Just wondering how much is involved in a swap of clusters produced in the same year not different years. BTW, I did read the entire post. Thank you for your reply
  39. Khufu
    5,704
    31
    whenever a cluster is swapped there is coding required. My concern is whether the speedo will be acurate as the S3 cluster goes up to 180mph instead of 160mph.
  40. NHN
    29,299
    1,702
    Depends if you're multilingual.
    Let me be frank, you have an A3 & you want to fit an S3 cluster, did you consider the fact are they both petrol, do they have the same rev limits, same speed limits etc etc, all relevant when swapping these things out, 09 to 09 if cluster matches then is simple for a dealer, there are variables to consider on any mod to your car, but why the hell would you want to add an S3 one in the 1st place, is that to get the lap timer & needle sweep feature, cause if not then pointless expensive exercise.
