'08 Audi A3 S-Line - Lowering advice
mattyg123 Jul 21, 2012
  1. mattyg123
    mattyg123 New Member
    29
    Hi guys,
    As above, i'm looking at some new wheels-18"s, and i'm thinking they will look that much better if i get the car lower.
    I've read to see a noticable increase on the S-line 40-50mm is the minimum you should look at.
    I've seen these;
    Audi A3 1.8 TFSI 03-11 H&R 45mm-50mm lowering suspension springs kit | eBay
    Any good?
    I'm in SW London aswell, I'd even go down the route of buying them through the garage that were fitting them to save hassle if anyone had any reccomendations?
    Matt
  2. NHN
    29,328
    1,708
    Talk to Damian@dpm about suspension, he's the man for the kit & advice tbh.
  3. rOb_A
    rOb_A Active Member
    1,488
    :iagree: Damian helped me out. the car height is spot on for me now i have the sportlines on
  4. Ads
    Ads License to drive
    8,230
    608
    Yep, for an s-line if you want to see a noticeable drop you are going to have to go for springs which lower 40/50mm below standard as s-lines are already 25mm below standard.
    However, if your car is quattro then you're going to be hard pushed to find springs that lower by anymore than about 5mm below s-line height.
    As for buying and fitting.... if you can get down to AMD Essex (Lakeside) they will supply, fit and laser align eibach or h&r springs for £300 all in.
  5. wez3570
    wez3570 Member
    704
    20
    +3 on speak to Damien at DPM, great price (ask him about price match) and even better after sales service.
  6. Jambo26
    Jambo26 Active Member Audi A3 Black Edition
    422
    25
    sorry to hijack, is the s3 sus set up the same as a sline set up??? just wondering, was reading Warren S3's build thread about him lowing the front only with 19's on, was wondering what would be best for a 2011 SB Black Editon tdi. wanted the front alittle lower but looking the rear seam as it could go alittle lower. dont want to drop it to much so its gonna catch or rub.
    cheers
  7. N8
    17,163
    718
    Damian @ DPM is the man.
  8. Jambo26
    422
    25
    is Damian on here??
  9. N8
    17,163
    718
    Yes.
