06A 133 789 - Do I have to go to the main stealers?
Wingnut Express May 15, 2013
  1. Wingnut Express
    Wingnut Express Audi sponsored by Mastercard
    124
    Guys I have been searching a boost leak and I found a couple of split hoses under the inlet manifold! I am aware that I could just delete the PCV and fit a catch can, but in this instance I would rather just replace this set of hoses, but is the Main Stealers the only place to buy this as paying for stuff direct from Audi is like automotive rape (so to speak!)
  2. Gops
    3,188
    647
    You could go to TPS but its probably more worth doing a catch can as it can be a lot cheaper. Can cost £25 and pipes etc cost £50 at the very max!
  3. <tuffty/>
    20,772
    3,655
    A full pipe set to go under the inlet is around 100 quid from TPS/Dealer
  4. Scullies
    Scullies Well-Known Member
    1,543
    657
    when one pipe goes I would say the rest dont have much life left.
    Catch can FTW
    kwistof likes this.
  5. <tuffty/>
    20,772
    3,655
    06A 133 789 is the expensive one if its the plastic pipe as its supplied with most of the bits fitted... technically you can bin it all off even without using a catch can...
  6. Wingnut Express
    124
    Thank you for your replies guys it is appreciated.
    If I was to go down the catch can how do you guys have do empty them? or is that a how long is a piece of string type of question
    Thanks again
