06 170 2.0TDI AVANT
tuffy Dec 11, 2012
  1. tuffy
    tuffy Member
    314
    13
    Hi guys
    im going to look at the above car at the weekend, it has covered 70k with full Audi sh, my question is ..... have Audi ironed out the oil pump issiues and any other common faults on the 06 model?
    Seems to be a contrast in opinions, some say yes, issues solved, others no.. steer clear
    Can anyone give me a straighy forward yes or no?
    Thanks guys
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,185
    106
    Hi tuffy not sure about pump,but 06 models seem to suffer with the injector/loom problem a mate in work suffered multiple injector problems ,then whilest at audi having second or third visit (out of warrenty)it had a bottom end failure whilest the dealer fitter was on test drive ,maybe pump?.After that audi sorted it all out and footed the bill.
  3. tuffy
    tuffy Member
    314
    13
    Thanks.
    wasn't the injector issue a recall warranty issue??
  4. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    It's not part of any warranty - they are recalling them.
    Call customer service on 0800 699888
  5. Paul B7
    Paul B7 Active Member
    622
    34
    Some 06 models have suffered from oil pump/balance shaft issues due tio the hex drive shafft rounding off. If you want to beat the oil pump issue you will need to buy a 2.0tdi from the B8 range.
    Paul B7
  6. ANDYTQ
    1,185
    106
    Not at first ,i printed off the injector thread and gave it to him and he gave audi some grief,they originally told him that it wasnt under warrenty(it had just run out),the dealer s had it for ages and didnt know how to fix it i think it was one of the early ones
  7. jaygeezer871
    jaygeezer871 Member
    166
    I have a 56, 2007 170 with the BRD engine.
    My injectors failed and they were replaced by an indie. Audi later took the car and replaced the loom and reimbursed me for the injectors.
    However there does not seem to be a definitive answer regarding the balance shaft/oil pump failure. Like you I have read & read the threads and it would appear to be chassis specific, at least that's what Audi say. I checked with them and mine is not affected, in truth I can't and refuse to believe them so drive the car daily hoping nothing happens. The only crumb of comfort is mine has only done 60k not 130k like a lot if you.
    Trouble is i love the car & if I was to sell it I would get a BMW which has its own issues.
    Last word, there are millions of very happy Audi owners and we on here are the minority with the doom and gloom stories, it may never happen. Imagine how big this forum would be if everyone came in here praising there car!
  8. tuffy
    tuffy Member
    314
    13
    Sorry for my ignorance but at what year does the B8 range start? is it as simple as 2008?
  9. tuffy
    tuffy Member
    314
    13
    So just to summerise the injector/ coil issue is not a standard recall? and if they fail you will have to wrestle the dealer for any joy?
    Can a 06 plate with a certain chassis number be clear of the oil pump issue? or is it only when you get to the B8 range?
    Finally has anyone replaced the oil pump/ balance shaft before it failed as a precaution ? Or is this not a sensible financial option?
  10. tuffy
    tuffy Member
    314
    13
    Forget that..... Just seen this code started in Jan 2007
  11. Paul B7
    622
    34
    The subject of the dreaded 2.0tdi oil pump balance shaft failures is dealt with in great detail in the November issue of Audi Driver.
    If you drive a 2005-2007/8 2.0 tdi powered B7 model and think you will be immune to this problem go read this article and think again .............................
