05 2.0 tdi juddering
stu_m Jul 10, 2013
  1. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    hey guys
    I have popped over from the B6 side to pick your brains
    My brother has an 05 2.0tdi 140 avant that has developed a problem
    it keeps juddering as if its misfiring! it does it a little at idle and it mainly does it when sitting between 1800 and 2000 rpm and accelerating through that rev range
    also it keeps going in to limp home mode if he boots it or when getting to near 80 mph which I think is overboost from sticking turbo vanes
    the turbo is a recent thing and I don't think its related
    anyone got any ideas?
    I am having a nosey at the weekend I have already had it on VCDS and all the injectors seem fine!
    Stu
  2. lukey baby
    lukey baby Member
    106
    12
    Engine mounts possibly?
  3. Noddy786
    Noddy786 Member
    i had this same problem on my 2.0tdi but it was only a very hard judder at idle...had my egr valve cleaned out and it solved the problem but i can slowly feel the judder coming back...
  4. stu_m
    1,440
    Thanks for the replies
    It's not engine mounts as I say it's like it's a misfire and does it at a steady throttle too
    Egr has been cleaned too as that was my first thought
  5. hubbo1
    hubbo1 Member
    116
    try replacing the vacuum actuator on the inlet manifold, it has a rubber diaphragm that is prone to splitting, this cured mine.
    you can also clean the swirl flaps in the inlet manifold while you have got it off.
  6. stu_m
    1,440
    thats twice I have heard that now!
    where is this actuator located and is there a way to test it? would clamping the vac pipe on it confirm whether it is that or not
  7. hubbo1
    hubbo1 Member
    116
    it is at the front of the engine on the inlet manifold, black plastic with small black vac pipe.
    you should be able to test it with a vacuum tester/brake bleeder kit
  8. mm707
    mm707 Member
    278
    Here is a pic of actuator. Cost about £10 from TPS and another £10 if you want to replace the gasgets. Easy to do. You will need a couple of cans of choke cleaner too for the inlet manifold flaps. Cured mine of hesitation at around 1800rpm and limp mode fault code 299.
  9. hubbo1
    hubbo1 Member
    116
    hi
    I got my actuator from audi £11.94 p/n A03G 129 061 C
  10. stu_m
    1,440
    I will check that out cheers
  11. stu_m
    1,440
    Well I had a little nosey today and this car does not have this valve!
  12. hubbo1
    hubbo1 Member
    116
    is the engine code blb? if so it will have this actuator, I will try and post a photo of the location
  13. stu_m
    1,440
    Not sure on the engine code I will find out tomorrow
    Looking at the pic above its to the left of the alternator next to the cam belt cover
  14. hubbo1
    hubbo1 Member
    116
    as you look into the engine it is just off centre to the right it is attached to the manifold
  15. stu_m
    1,440
    Nope definitely not there
    Wonder if some have it and some don't
  16. mm707
    mm707 Member
    278
    Mine is a 2007 so maybe it wasn't on the 2005 ?
    Have you checked the air filter ?, I read on another forum of someone having similar problems and it turns out his air filter was really clogged up - he changed it and fixed the problem.
  17. stu_m
    1,440
    Yeah it's been changed along with the fuel filter too
    I took the car for a drive today and no juddering at all yet it was doing it for my brother on the way home from work
    Its going to get stripped tomorrow to check vac lines etc
  18. hubbo1
    hubbo1 Member
    116
    mine is a 2005 140 tdi-strange yours hasn't got one
  19. ukdan
    ukdan Member
    72
    Had a look at mine today and I can't see one either.
    2005 BLB.
  20. stu_m
    1,440
    I'm pretty sure this engine is a BLB too
    Its not my car so can't check at the min
  21. hubbo1
    hubbo1 Member
    116
    [​IMG][​IMG] this is what is on my 2005 blb 2.0 tdi 140
  22. onearm35
    onearm35 New Member
    how hard is it to change the actuator as mine is playing up at 1800rpm at low speed thanks
  23. hubbo1
    hubbo1 Member
    116
    not too hard, egr valve has to come off then the inlet manifold, took me a couple of hours.
  24. ifsot
    ifsot New Member
    mines a 54 plate 2.0 tdi blb and mine does not have one too
  25. .Jas.
    .Jas. Member
    134
    When you checked the injectors on VCDS did you do output tests while the car was running?
