049682 - Steering Wheel Control Module
lgooch
Well-Known Member
East Manchester In the Hills !
Just done a scan of my car after clearing the codes and this one keeps popping up
Address 01: Engine (CDA) Labels: 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 L HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0030
Revision: AAH03--- Serial number: AUX7Z0I5FNA05J
Coding: 0103000C18070060
Shop #: WSC 06314 000 00000
VCID: 428D26841D0AFE52EA-8016
1 Fault Found:
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 57 /min
Load: 78.8 %
Speed: 255.0 km/h
Temperature: 27.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 5.969 V
Readiness: 0000 0000
Anyone got any ideas, not much on the tinternet about it. Everything seems to work ok on the steering wheel but I am selling the car and wanted to give the buyer a print out of the scan to prove there are no issues.
Any help appreciated peeps
I am new to Audi electronics and even newer to VCDS, so might not be much help - but with Mercedes there were no end of problems with steering column modules.
The problem with the MB ones was that they had to be re-programmed each time various new components elsewhere were fitted eg, radio, angle sensors and the like. So I just wonder if you have anything replaced that might cause the same issue that you could get the module paired with the car again...
The other big issue - and this would go with your message of intermittent communication - was earthing, wiring and ribbon connections, either loose or dirty. Might be worth a try an check all connections in that area.
Hope it might help.
