04 1.8T engine management light on! Advice please
Ratha Dec 1, 2010
  1. Ratha
    Ratha New Member
    My girlfirend has a 1.8T 04 plate A4 cab. she started it the other day and the engine management light came on and it started to run lumpy, as in sounding like it was a cylinder down. I have checked the core/coil plugs and found that the number 1 cylinder wasnt working. i have replaced with a genuine VAG part and it has sorted the issue, as in all of the cylinders appear now to be working and when you remove all of the the core plugs you can see it sparking and hear them clicking etc. however it is still running very lumpy when idling. It appears to cure when you give it some revs partly. Any ideas?
  2. AU01 A4
    AU01 A4 Member
    211
    Crank Brather vale there a lot of threads on here about it
  3. AU01 A4
    AU01 A4 Member
    211
  4. Ratha
    Ratha New Member
    cheers, gives me a place to start looking. I'll get it scanned.
  5. pj123
    pj123 Member
    307
    13
    Poor idle can be from any of the following:
    MAF, Ignition Coil, Spark Plug, VAC Leak, O2 Sensor, Throttle Body or Temp sender.
    Cleaning the TB is a cheap an easy place to start.
    Unplugging the MAF tests if the MAF is faulty
    Temp sender / o2 sensor you'll need to do a scan.
    Vac leak, look for split hoses or data logging using vag com
    Not sure if the 3 older coil packs are weaker in any way and could make a difference?
  6. CHRIS555
    CHRIS555 DOPE with added OCD
    1,966
    10
    Crankcase breather valve for sure - let ne kniw if you need the part numbers etc, its a £6 part and a DIY job
  7. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    I had the same problem on my cab, I replaced the valve and it cured the problem. Easy job to do
