03 s4 electrical problem
TURBOTRONICS Oct 27, 2011
  1. TURBOTRONICS
    TURBOTRONICS Member
    187
    hi all i noticed tonight that when i locked my car the alarm never gave the usual beep noise
    so i checked all the doors and tried again but still no beep when arming the alarm
    next i notice that non of the windows would work or the electric mirrors and also the central locking button wasn't working on the door
    so i checked all the fuses by the drivers door and they all seem fine
    then i noticed the lights was staying on inside the car after locking the doors with the remote as if one of the doors was open
    and the last thing is the drivers door wont lock or unlock on the remote even when all the other doors do
    its as if the drivers door has lost all power
    can any one suggest what might be causing this
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    have you had a wet passenger footwell/ if so under the carpet there is the convenience module that controls all of those features you mention i believe. check under your bonnet where the battery is and see if there is standing water. There are some bungs which block up causing the water to run into the passenger side via the pollen filter housing and fry the module. Worth checking sooner rather than later as the ecu and brake servo are in there also.
  3. hades-
    9,481
    646
    could also be the wires goin from car to door very comon
  4. TURBOTRONICS
    TURBOTRONICS Member
    187
    iv checked the foot well for water and it doesn't seem damp at all
    so im hoping its the cables to the door
    dose any one know if theres a page that tells you how to remove the plug if there is one or how to check them
    colour codes and what each wire dose
  5. hades-
    9,481
    646
    just pull the rubber boot back
    u have to tug at the wires they break but look conected
    mainly the thin blue brown and the thick brown
  6. TURBOTRONICS
    TURBOTRONICS Member
    187
    had a look at weekend and it turns out to be the brown thick wire had snapped in two
    re joined the wires and its all working fine now
  7. marktdisport
    marktdisport Active Member
    1,195
    15
    mine done the same !!! must be very common failure...
