03 Passat 1.9 PAS PUMP issue
S4_dan Dec 30, 2013
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,762
    167
    Hi,
    My sisters Passat has a 'chatter' noise when setting off and turning or when near full lock moving slowly. A garage diagnosed it as a failing tensioner and replaced it along with the belt.
    Howver, it didn't sure it. I had a look and the noise is the from the PAS pump! The pump is slowing down causing the belt to spin on the pulley. So for £40 she got a 2nd hand pump thinking the pump may be seizing.
    Today I fitted said pump, drained all of the old fluid, filled with fresh, ran for a few mins then drained and refilled. All now nice and green but it still doing the same thing!
    It's as if something is restricting the high pressure side flow and causing the pump to slow up momentarily.
    Is it the rack that is causing this? Or maybe the filter in the reservoir? But this was pushing fluid up when draining and turning the wheels lock to lock. (Obviously nut under the same pressure though as the engine was running...)
    Dan
  2. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    6,105
    2,811
    Hello Dan have you checked the one way clutch on the alternator is working OK. These can cause all kinds of issues with the belt jumping.
    It should be locked in one direction and free wheel in the other.
    Karl.
  3. S4_dan
    2,762
    167
    IIRC the Alternator pulley could turn in either direction?
