02 S3 Scan Fault code thoughts !
mattyboy199 Nov 22, 2012
  1. mattyboy199
    mattyboy199 Well-Known Member It's my birthday
    1,885
    Just did a scan on the S3 as i'm aware something is up the EML & some hesitation uner boost, got the following.
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 01 0001
    Coding: 10710
    Shop #: WSC 00000
    VCID: 78836BE34BCB
    2 Faults Found:
    17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
    P1114 - 35-00 - -
    16502 - Shareware Version. To Decode all DTCs
    P0118 - 35-10 - Please Register/Activate - Intermittent
    Readiness: 0000 0000
    Can a lamda sensor influence fueling enough to cause hesitation ? or could this be an issue with the MAF ?
    Any help would be great
    Regards
    Matt
  2. Sevv
    Sevv Pushing the limits..
    1,321
    118
    check your o2 sensors mate.. might be wiring or you might need to replace them ... no other fix comes to mind .. or try to clean then maybe ?
  3. mattyboy199
    1,885
    yeah i need to get under there & take a look, if anyone has the part number that would be helpful
  4. Sevv
    1,321
    118
    best bet is to call awesomegti think u can get both for 180 pounds iirc and genuine. qoute Mike there you VIN and ur gd
