01314 - Engine control module problems - help?
tates1979 Mar 28, 2011
  1. tates1979
    tates1979 Member
    52
    Folks - have jumped over from the A3 8P forum, hope someone can shed some light on this VCDS scan.
    The 1.9tdi Sportback is cutting out going over bumps - have checked physical connections etc. The scan my mate performed below reveals the repeated 01314 code regarding the engine control module - could this be causing the problem?
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 CC HW: 028 101 183 2
    Component: R4 1,9L EDC 0000SG 6231
    Revision: 12345678 Serial number: AUX7Z0D9FND0BK
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 N
    Component: ASR FRONT MK70 0103
    Coding: 0017025
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    Revision: 105846 Serial number: 8P0820043D
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 198
    Reset counter: 119
    Mileage: 226825 km
    Time Indication: 0
    Date: 2010.09.18
    Time: 21:59:02
    Freeze Frame:
    Temperature: 4.5°C
    Voltage: 12.10 V
    RPM: 0 /min
    Load: 0.0 %
    Load: 9.0 %
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001126281
    Coding: 01884F02B214100000160000160000000000FE0F5C
    Shop #: WSC 00000 000 00000
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    3 Faults Found:
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
    010 - Open or Short to Plus - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 2620
    Revision: 91H10262 Serial number: 00362000RVWF
    Coding: 0033622
    Address 16: Steering wheel Labels: 1K0-953-549.lbl
    Part No SW: 1K0 953 549 HW: 1K0 953 549
    Component: Lenksäulenmodul 012 0030
    Coding: 0000002
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 900 F HW: 8P0 920 900 F
    Component: KOMBIINSTR. VDO H72 0210
    Revision: D03 Serial number: 1249DD03013973
    Coding: 0004448
    Shop #: WSC 00411 210 03906
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001049270233
    Coding: 3D3F0B42072103
    2 Faults Found:
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 119
    Mileage: 232699 km
    Time Indication: 0
    Date: 2011.02.11
    Time: 17:20:30
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 233477 km
    Time Indication: 0
    Date: 2011.02.28
    Time: 18:53:32
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D03 Serial number: AUX7Z0D9FND0BK
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000016
    1 Fault Found:
    00912 - Window Regulator Switch; Front Left (E40)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.9 1301
    1 Fault Found:
    Freeze Frame:
    Mileage: 3440 km
    Temperature: 20.0°C
    Voltage: 12.50 V
    Voltage: 12.30 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 E
    Component: KSG H04 0050
    Coding: 188000186D088505489F016000
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH02 0160
    Revision: 00001 Serial number: 10000001189590
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000016
    Address 56: Radio Labels: Redir Fail!
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3D1535597
    Coding: 0001001
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG H10 0010
    Coding: 0000144
    1 Fault Found:
    00934 - Electric Window Motor; Rear Left (V26)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    End ---------------------------------------------------------------------
  2. mike foster
    3,967
  3. NHN
    29,427
    1,740
    Check the ecu connector isnt loose as thats what it seems like.
  4. ignagon
    ignagon New Member
    I have te same fault, please could your tell me the solution.
    Many thanks in advece.
  5. ignagon
    ignagon New Member
    tates1979 greetings, looking into the WEB I saw that your had a fault on your car the same as I have on my car a SEAT LEON2, please can you tell me what was the solution working.
    thank you very much in advance and sorry for my English I'm a Spaniards boy
  6. Audi Toby
    Audi Toby 2016 S3 Saloon
    256
    51
    Sure does seen like a ecu/loom connection problem
  7. ignagon
    ignagon New Member
    according Mr. A4 Toby, My fault seems to be a connection problem, because the report that shows me the my WAG-COM are equals as the one written above by Mr, tates1979 , I would like to know what was the solution, or where I can find it.
  8. Audi Toby
    256
    51
    Hola, todos los códigos de fallo tiene son signos de que todo es pérdida de potencia, ?cómo está la batería del coche.
    Sus inglés es bueno por el camino. espero que mi español es al nivel de los estándares.
    Toby
  9. NHN
    29,427
    1,740
    Toby, with respect, this is an English forum, please keep it that way or PM the other member in a language that suits.
  10. Audi Toby
    256
    51
    Ok.
    Here's English Translation:
    Hello, all fault codes are signs of a loss of power, how is the car battery? It is a intermittent loss of power which could be the ECU loom.
    Pm me your response.
    Toby
  11. ignagon
    ignagon New Member
    A4 Toby, this is my AutoScan:
    Friday,01,June,2013,17:18:53:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN: VSSZZZ1PZ6R045827 Mileage: 225890km/140361miles
    02-Auto Trans -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 EC HW: 028 101 176 5
    Component: R4 2,0L EDC G000AG 8074
    Revision: 12345678 Serial number: SEZ7Z0E3217857
    Coding: 0050078
    Shop #: WSC 06441 785 00200
    VCID: 68D5A6795B68FA9
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 T HW: 02E 927 770 AE
    Component: GSG DSG 070 1104
    Revision: 04507000 Serial number: 00000510210479
    Coding: 0000020
    VCID: 244DF249E7C0DE9
    1 Fault Found:
    18258 - Powertrain Data Bus
    P1850 - 000 - Missing Message from ECU - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Reset counter: 40
    Mileage: 225846 km
    Time Indication: 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
    Component: ESP FRONT MK60 0102
    Revision: 00H13001
    Coding: 0006786
    VCID: 71E3CB1D68B23B1
    1 Fault Found:
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1P0 907 044
    Component: ClimatronicPQ35 001 0302
    VCID: E9D3237DC062431
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
    Component: Bordnetz-SG H37 1002
    Revision: 00H37000 Serial number: 00000003628991
    Coding: E1880F2F00041000001D00000000000000007F075C
    VCID: 2B5F19758A1E111
    Subsystem 1 - Part No: 1P0 955 119 A Labels: 1KX-955-119.CLB
    Component: Wischer SE350 012 0403
    Coding: 00056272
    Shop #: WSC 06441
    Subsystem 2 - Part No: 1P0 955 559
    Component: REGENLICHTSENSORH01 X010
    Coding: 00137517
    Shop #: WSC 06441
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 70
    Mileage: 225846 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 12.70 V
    ON
    ON
    OFF
    OFF
    ON
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
    Component: R3 AIRBAG VW8 027 2521
    Revision: 09027000 Serial number: 003A1PPWWUPB
    Coding: 0021043
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
    Component: J0527 634 0070
    Coding: 0012042
    VCID: 77F7F50506D6651
    Part No: XXXXXXXXXXX
    Component: E0221 005 0060
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1P0 920 840 C
    Component: KOMBIINSTRUMENT VO3 0518
    Coding: 0002101
    Shop #: WSC 03321 572 97198
    1 Fault Found:
    Part No SW: 1K0 907 530 F HW: 1K0 907 951
    Component: Gateway H10 0120
    Revision: H10 Serial number: 2800105B108B79
    Coding: 3F3F03C0070202
    VCID: 2A511C7185E4089
    1 Fault Found:
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VO3 0518
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
    Part No: 1T0 959 701 C
    Component: Tuer-SG 024 2451
    Coding: 0000176
    VCID: 377735054656A51
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 J
    Component: EPS_ZFLS Kl.5 D04 1606
    VCID: 32610411AD34409
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 AK
    Component: KSG 0401
    Coding: 19C000BC090905054C4F863004CC
    VCID: 79F3F33D30C2731
    Subsystem 5 - Part No: 1P0 951 171 A
    Component: Innenraumueberw.010 4974
    Coding: 00000000
    Shop #: WSC 00000
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
    Part No: 1T0 959 702 C
    Coding: 0000176
    VCID: 387536394B48AA9
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1P1 035 186
    Component: Radio BVX 0017
    Coding: 0042400
    Shop #: WSC 03321 572 90108
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 G
    Component: Tuer-SG 021 2420
    Coding: 0000144
    VCID: 346D020957204E9
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 G
    Coding: 0000144
    VCID: 356B3F0D5C5A571
    Address 77: Telephone Labels: 5P0-862-335.lbl
    Part No SW: 5P0 862 335 A HW: 5P0 862 335 A
    Component: FSE_2P5x H18 0050
    Revision: 00000001 Serial number: 00000000325053
    Coding: 0000555
    VCID: 31630B1DA8327B1
    End
    I think that is a communication fault between different ECU and the engine ECU as you can see is the same as the above roreported by tates 1979.
  12. NHN
    29,427
    1,740
    You're using a fake counterfeit cable, this forum doesn't support the use of these.
