005 - No or Incorrect Basic Setting / Adaptation error after SRI reset
fizz Jan 6, 2013
  1. fizz
    fizz Member
    264
    Hi
    Would anyone be able please advise how to reset the service light on an Audi A3 57 plate TDI 2.0 SLine with VCDS as I have followed the documented procedure here Ross-Tech: VCDS Tour: SRI Reset but now get the following error:
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 J HW: 8P0 920 982 J
    Component: KOMBIINSTR. VDO H02 0980
    Revision: D0H02002 Serial number: 2246I002005548
    Coding: 0005428
    Shop #: WSC 00618 210 91773
    VCID: 40849B341364CC18615
    1 Fault Found:
    00003 - Control Module
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 36109 km
    Time Indication: 0
    Date: 2012.12.04
    Time: 19:54:23
    Although the light has now gone off, error appears when scanning. This is very frustrating as I would of thought the procedure to reset the service would not bring an error. I emailed rosstech a few times on their support address but have not yet received a reply. FYI I am using a HEX CAN USB (Genuine) cable. Any help appreciated guys.
  2. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    From memory:
    With the ignition on, pull out the trip reset knob and then let it go and then pull again and hold for about 5-10s it will reset the service indicator.
    Regarding the fault code:
    From Rosstech wiki:
    When found in Audi A3/S3 (8P): Instrument Cluster:
    • Check/Perform Instrument Cluster Service Interval Settings (Adaptation Channels 42, 43, 44, 45 and 49)
  3. fizz
    fizz Member
    264
    thanks for the heads up, however got a reply from Peter at ross-tech too with the following thats sorted the issue:
    Just incase anyone else comes across this problem I got a reply from Peter from ross-tech with the following thats now cleared the code:
    "You may need to manually adapt the channels. To reset these to factory
    > default settings, follow the
    > Select Address 17-Instruments
    > [Adaptation]
    > Enter in Channel [42], Read
    > New value = [145]
    > Enter in Channel [43], Read
    > New value = [300]
    > Enter in Channel [44], Read
    > New value = 730]
    > Enter in Channel [45], Read
    > New value = [2]
    > Enter in Channel [49], Read
    > New value = [730]"
    The difference from my original adaptations was channel 43 was set to 306 instead of 300. Hope this helps somebody.
