00470 Fault Code - Help required please
Avus Sportback Aug 26, 2013
  1. Avus Sportback
    Avus Sportback Member
    116
    Hi All,
    ive just fitted a genuine towbar loom to my A3 this afternoon, since connecting it and enabling in the Can Gateway #69 Trailer, I now have the below fault showing....
    i haven't changed any other parameters other than enabling #69 Trailer
    any ideas as to what I've done wrong?
    below info fron Ross Tech website
    00470 - Combination comfort Databus in Single Wire: Open Circuit
    Possible Symptoms
    Data Bus Comfort working in Single-Wire Mode
    Possible Causes
    Wiring/Connectors from/to Control Modules
    Control Module in CAN Data Bus Comfort faulty
    Possible Solutions
    Check Measuring Value Blocks (MVB)
    Check Wiring/Connectors from/to Control Modules
  2. NHN
    29,561
    1,778
    1 of the canbus wires isn't connected properly or at all, hence single wire error.
  3. Avus Sportback
    116
    Ok thanks, I take it they are the two orange wires (orange/green and orange/brown)?
  4. NHN
    29,561
    1,778
    Indeed.
  5. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    u can check ecu measuring blocks around 125 and maybe up and down a few to see if anything shows up, no number is not installed, 1 is working 0 is failed connection iirc.
  6. Avus Sportback
    116
    #Confused ?
  7. NHN
    29,561
    1,778
    Just check your wiring for now.
  8. Avus Sportback
    116
    Ok, checked wiring tonight and all appears to be in order, I connected the two can bus wires to the back of block "G" using Scotch locks, its wired exactly the same as it was on my 2007 A3?
    I have attached the below screen shots to try and give you some info, I'm not an expert with VCDS and don't really know how to use it for things like this.
  9. NHN
    29,561
    1,778
    Scotch locks are shxt, do it properly & solder :)
  10. Avus Sportback
    116
    You still convinced it's these two wires into the back of block "G"?
  11. NHN
    29,561
    1,778
    Block G where, ce module??
  12. Avus Sportback
    116
    Yes
  13. NHN
    29,561
    1,778
    As I said remove scotch locks & test wound around the wires directly, as scotch locks are **** & don't connect very well at times, I never use them.
