  1. jackpilk
    jackpilk Member
    70
    The S3 seems like it hasn't got a turbo. It was Boosting fine earlier and was pulling really strong and now it feels like I've got back to my old 1.4 golf.
    I've disconnected the MAF and still runs exactly the same, checked all the breather lines for splits etc (The one's under the inlet manifold were replaced quite recently) and from I can see they are all still intact as well as all the main hoses. Could I be dealing with a big air leak?
    This happened to me the other day but then all of a sudden I had boost again, could mine be flickering in and out of 'limp' mode?
    Anyone been in a similar situation?
  2. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Is it remapped?
  3. jackpilk
    jackpilk Member
    70
    It's not remapped
  4. camscockle20vT
    1,740
    77
    Ok dude, id suggest getting it on vag com/ross tech to see if there are any fault codes, before throwing money down the drain.
  5. jackpilk
    jackpilk Member
    70
    I'm off working abroad next week so I'l have to sort it when I'm back. Just not nice knowing you will return to a dud car.
  6. Metro
    Metro Error
    381
    No engine management light?
  7. jackpilk
    jackpilk Member
    70
    No Engine light, Idle is a bit floaty but only very very little. Smooth power through the revs just no turbo kick at all
  8. Sevv
    Sevv Pushing the limits..
    1,321
    118
    mate id check it on vag com first , check the boost pipes going from the DV to the hard boost pipe and your DV, check also your hard boost pipe, and i would suggest checking on the turbo its self
  9. Dani_B19
    9,110
    346
    Limp mode.
    Benjiman46 likes this.
  10. actualeddie
    actualeddie Member
    211
    It would sound like a woosh of air all aorund you if the orange/red pipes come off, at least it did with me
  11. Sandip
    2,440
    91
    What's your location bud? There might be someone local to you that can scan it :)
  12. marshall-12
    marshall-12 Member
    208
    i had this problem with my old golf gt tdi.
    no turbo at all, i checked everything these guys have checked, even took pipes of the turbo to check the blades etc thinking the turbo had gone, plugged it into vagcom got some stupid codes with reason i had never heard of lol
    sent it to a mates garage, to find the cam belt had skipped a tooth or 2 and the tensioner was on its way, and causing the car to go into 'limp' mode every time i started it up.
    my advise if it isnt anything simple, send to a garage where you have warrenty cause starting it up a load of times could make it worse, and if my cam belt had snapped... thats big money lol.
    but still, could be something simple.
  13. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,171
    214
    Which are the orange/red pipes? Where are they located?
  14. actualeddie
    actualeddie Member
    211
    [​IMG]orange/red pipe is at the back of the engine, goes down into the top of the turbo, OEM is known to go; mine went recently. comes of the metal pipe that goes around the left side of the engine
    Audi A3 TURBO HOSE £58.34 at Motorsport World
  15. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
  16. ShaunS3
    1,171
    214
    I do get some boost pressure, but it feels as though when it's up to a decent pressure, it leaks out and causes a loud hissing noise from the engine bay. Mine is stage 1 mapped with an OE airbox (upgraded panel), forge tip and a (new/replaced) Forge 007p that is 2 months old. Thought it was the DV but i have swapped it and the power loss is still there.
  17. actualeddie
    actualeddie Member
    211
    if its off slightly you get a hissing noise, take it off and have a look for wear. Its a 10min job on and off. I used the hairspray trick around the rim of the red pipe when refitting it.
  18. ShaunS3
    1,171
    214
    Cheers pal, will have a look tonight after work. I presume the hairspray trick is to act as a sealant to prevent it slipping of again?
    Shaun.
  19. actualeddie
    actualeddie Member
    211
    yea thats right, also found it slips on easier when wet too
  20. jackpilk
    jackpilk Member
    70
    Sorry for the late reply.. Who ever said limp mode give yourself a shiny.
    It goes in and out quite a lot. Car has properly died now and sounds haggid on turn over, oh the joys of s3 ownership.
