£45 to 155 miles ..
motfree Nov 26, 2010
  1. motfree
    motfree Member
    464
    Had my s3 for about 2 weeks now and I think I've done about 300 miles and it's cost me not far off £100
    Over yesterday and today I put £45 of fuel in and the light came on after 155 miles - mostly driving about 50 with the odd little blip .. Is this normal or is there something wrong ??
    Also just filled up £62 and it's only showing as 3/4 tank my heads baffled it just doesn't seem right
  2. finesse
    finesse Active Member
    2,805
    More info...
    Is it mapped?
    On average £20 the motorway should get you 150 if "sensible"
  3. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Somethings's wrong, I get nearly 200 miles off £30's worth of VPower at around £1.25/litre.
  4. sportquattro
    sportquattro Active Member
    835
    51
    £60 takes me about 375 miles on average, sounds like you have a problem, get it on VAG-COM and see whats amiss
  5. motfree
    motfree Member
    464
    Straight through system including decat
    Remap
    That's all I know off .. Mpg calculator was averaging 35 mpg that's what I don't get .. But fuel gauge was playing up the other day going from full tank to 0 then upto half and so on so was told the receiver was goosed but clearly it's actually using that much as £63 must fill the tank ??
    No smell of fuel so definatly not a fuel leak
  6. motfree
    motfree Member
    464
    You mean get it pluged in on vag com ?
  7. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    really? what sort of driving do you do? motorway etc..?
    I will average around the doors 80-90 miles to 20 quid!!
  8. motfree
    motfree Member
    464
    So mine isn't too far off then I guess .. That with you taking it easy ?
  9. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    yea steady away,give it beans every now and again,the cold weather has not helped and ive seen the mpg fall,but my s3 has revo stage 2 and all the usual,plus ive got no fault codes,new air mass,n75,plugs etc.....my mate does about similar mpg,but mine on the run can see far better as you would expect.
  10. S3KO4
    S3KO4 Member
    850
    Check if you have 4 bar fuel presure regulator, this shows better mpg on the dash but in fact I would say it's up by 8-10mpg. so if you get 36mpg it's more like 26. Decat does not help at all.
  11. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    this directed at me? im running the stock 3.5 bar regulator as revo specified?
  12. S3KO4
    S3KO4 Member
    850
    Well I would say to anyone who has a 4 bar. the standard one is 3 bars. but that's my little finding with the FPRs I have used.
  13. Kave
    Kave Member
    160
    Yeah this cold weather does make a noticeable difference in mpg, mines dropped to 48mpg! Only just getting 600 miles / tank now, bloody winter. On the plus side you s3 boys must be noticing a nice increase in power with the plentiful cold dense air?
  14. sportquattro
    835
    51
    James, Thats a daily drive to work of 40 miles each way on the motorway at about 80, mixed in with few local journeys of around 5 miles or so, if out of the way fo the boys in blue and giving it beans it drops but not by much, a banzai trip halfway across Devon and on up to Guildford last August early on a Sunday morning returned 27 mpg and gave 305 miles out of a tankful. I've never ever had less than that from a tankful. Hope you get it sorted.
    Nige
  15. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    i can but dream of getting 600 miles to a tank lol
  16. motfree
    motfree Member
    464
    I've filled the tank up to the brim couldn't get anymore in and it's only showing 3/4 tank ?? Maybe it is the sender ?? How much does it cost everyone else to fill an s3 from reserve ?
  17. S3KO4
    S3KO4 Member
    850
    £70
  18. motfree
    motfree Member
    464
    Oh I don't know haha have to clean out the sender and go from there .. Fuel pressure regulator under the bonnet ?
    So If a full tank is £70 that means I've definatly used £45 on 150 miles thought the tank might have been bigger Eg £80 so would have been the sender not working properly :-(
  19. fingermouse
    fingermouse thats me
    3,999
    111
    What size wheel have you got on ??? I know I get approx 30 miles less to a tank of fuel with 235/19. I get 300 to 330 on a full tank to empty.
  20. shanejess
    shanejess Guest
    i have a A3 170tdi s-line Black edition remapped by giac to 195bhp, its a company car i do between 490 and 510 miles per tank, my 03 reg S3 does between 310 and 330 miles on a full tank.
  21. LiveWire
    LiveWire S3X
    329
    So running 19's with wide tyres uses more fuel!! Surely not?
  22. motfree
    motfree Member
    464
    What could be up with mine then as my range on the dash is 160 miles and that's full ?? And ive filled it till I can't get no more in and its only showing 3/4 tank :-S !!
  23. fingermouse
    3,999
    111
    sounds like the sender, its under the back seat behind the driver, run the tank down then pull the pump to a angle to remove the circuit board like sender. I cleaned mine up a few weeks ago and its reading fine now.
  24. fingermouse
    3,999
    111
    yup would you credit it who would have guessed ........................................
  25. LiveWire
    LiveWire S3X
    329
    Please can you explain how? I am curious :eek:)
  26. JS1500
    JS1500 Howdy
    1,166
    10
    Typically i've been getting 280 miles to a full tank of V-Power (£72+). DIS showed roughly 25mpg.
    Last full tank got me 250 miles :( - DIS showing 22mpg.
    I do a lot of short journeys, leave it to warm-up and cool-down, commuting in stop/start traffic and it's hilly around here to be fair.
    Still getting it checked/possible replacement thermostat on Monday.
  27. motfree
    motfree Member
    464
    But If it was the sender it wouldn't use the fuel ... Did 20 ish miles today and the car took £10 to fill !!
  28. fingermouse
    3,999
    111
    wider tyre = greater resistance = less mpg
    My brother in law fitted some stupidly wide wheels to a old corsa that killed the mpg totally.
  29. scoobyra
    scoobyra It's not f@cking ORANGE!!!!!
    798
    I get 25 miles to a fiver and around 45 miles to a tenner (don't even criticise the maths as I know it doesn't add up lol) round town or on short journeys with my Revo (variable - it'll do what it wants) map in the Red car and about 340 miles to a full tank on the motorway.
    The black car does about 15 miles to a fiver if I'm lucky!
