£29 induction kit solution!
JJ.Foulds Sep 24, 2013
  1. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    So here it is! £13 for filter £16 for the pipe.
    and the filter can be used later on for the end of the mtc copy of the itg induction kit when i have the money to do it properly.
    Uploaded with ImageShack.us
    no idea about performance, probably wont increase much, may even be worse?! who knows. However it is a bit louder and can hear it better later on in the rev range. Saving up for the proper intake in the mean time!
    JJ.
    Westy, superkarl and sliced like this.
  2. mjr901
    mjr901 Guest
    Have you removed the standard air filter? else you'll be filtering air twice....ie it'll be more restrictive.
  3. JJ.Foulds
    1,263
    176
    o yes, forgot to mention, i did remove the original filter!
  4. Jonni
    Jonni Active Member
    268
    46
    Look ok for the money but black filter would look better tbh
  5. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
    It is not a looker for sure :ninja: but 29 quid is a good price
  6. Jonni
    Jonni Active Member
    268
    46
    Yerh and the air will still have to pass through the standard restrictive air box
  7. JJ.Foulds
    1,263
    176
    Well its just a square space in the old filter bay now, so that would help right? lol.
    and yes probly not the best looker!
    JJ.
    leegsi likes this.
  8. mramage
    mramage Member
    516
    Does it sound or feel any different?
  9. JJ.Foulds
    1,263
    176
    it sounds louder, i can hear the air dump noise much better which is a nice change.
    and while moving it deffo feels tighter on the throttle, more instant than it did before.
    JJ.
  10. Westy
    Westy Well-Known Member
    17,443
    1,105
    I'm still yet to have a good look at the 2.0 TDI engine so forgive me if I'm being a touch dim but does the filter not pipe straight to the turbo?
  11. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Are you sure that when you remove the OEM air filter that you haven't got air gaps where the rubber seal for the air filter used to be? If so you'll be sucking in dirt and pitting the impellers on the turbo.
  12. JJ.Foulds
    1,263
    176
    No. Its right at the back behind the engine. All the kits pope it round the back then to the front
  13. XFi
    XFi In need of a V8.
    491
    47
    This is what I was going to say, mine had a few gaps on the standard airbox where the filter helped seal...
    warren_S5 likes this.
  14. warren_S5
    7,210
    2,488
    I was going to suggest cutting the paper element out of the seal and leaving the rubber seal in the airbox aperture.
    I guess only time will tell if he thinks it's ok. As the turbo spins up to 100,000rpm even the slightest dust particle can accelerate and pit the turbo impellers, I hope for your case this is not so, but I'd get it checked just in case.
  15. JJ.Foulds
    1,263
    176
    Yeh there were 2 tiny holes but i just left them ahaha while i was testing it. But easy to cover them, but never bothered lmao caus got the kit on the way
  16. warren_S5
    7,210
    2,488
    A turbo sucks air like you wouldn't believe from ANYWHERE! Forced induction means literally that. I would tape those holes up immediately as otherwise your money saving intake will land you a sizeable bill. If you don't believe me call a tuning company and ask their view.
  17. JJ.Foulds
    1,263
    176
    Yeh i belive you, iv not had my car like this for a while. But i remember when i took off the whole engine top and forgot to put it in the next day and drove off.
    I was a bit worryed half way, but on the plus side it sounded AWESOME!!...
  18. Wicked666
    Wicked666 Active Member
    584
    35
    Wouldn't this just suck hot air from the engine?
  19. Westy
    17,443
    1,105
    The turbo will make it hotter anyway ;)
  20. Flexiblemouse
    Flexiblemouse Active Member
    258
    60
    I hope you cleaned out the dirty side of the airbox... If not then all the crud coating the inside is now behind your filter...
  21. JJ.Foulds
    1,263
    176
    yep i made sure it wasnt dirty inside :p
  22. S3_Jacko
    S3_Jacko Well-Known Member
    1,734
    575
    Did you not have the MTC kit installed
  23. warren_S5
    7,210
    2,488
    :sign_omg:
  24. Tom5190
    Tom5190 Active Member
    318
    139
    43
    It's not always the case, you can create changes in air pressure and turbulence in an open space that's not the correct shape/design. You can sometimes find that an open space is more restrictive than having a filter in it dependant on a lot of characteristics. The same effect (in reverse) can be seen with an exhaust for instance, you will find that removing a silencer box and sticking a straight piece of pipe in its place will sometimes drop the power a small amount.
    The box itself is a really bad shape for air flow (I'm pretty sure that's deliberate?.)
    The air temps will probably be pretty much the same as the original filter set up
  25. Westy
    17,443
    1,105
    Air temps aren't really that important with a forced induction intake system as the turbo will make it a lot hotter and it's the intercoolers job to cool the charge air as much as it can before it enters the engine. Obviously density of air comes into play too and te cooler the air the better.
    A turbo can only take on and process a certain volume of air depending on its size etc. the best induction kits are normally the ones that allow the turbo to take in as much air as it can.
    Some serious gains have been had on the 1.8t engine just from allowing the turbo to flow easier and the 2 biggest restrictions have been the TIP and the filter.
    Has anyone done any extensive testing with a 2.0TDI to see what works best?
  26. warren_S5
    7,210
    2,488
    Not seen any threads on 2.0TDI filters recently, particularly including extensive testing.
    The 2.0T has had a lot of research conducted and one of the things that was noted during the testing was that unless you are going to write a bespoke remap to include MAF scaling then the 2.0T engine cover has a 67mm MAF pipe and this needs to be maintained for replacement pipework. The system isn't ideal as there are many kinks in the pipe of aftermarket units as the pipework meanders round to the front of the bay. At least the OEM engine cover as flawed as it is allows air in without so many right angle bends in the pipework. The standard filter is good for 300bhp, but it's worth increasing the surface area if you intend to go significantly beyond that (I'm led to believe that the outer surface area of the filter media is directionally proportional to how much outright power that can be delivered by the turbo. So whilst you can de-restrict all the pipework, you'll always have to factor in the MAF pipe as the greatest restriction.
    Westy likes this.
  27. max69vk
    max69vk Active Member
    862
    57
    Don't bother with doing anything to the TDI filter, the standard box & filter are good enough for over 230bhp as is the intercooler. After market filters tend to play havoc with the MAF, usually meaning having to replace it after a short period of time. TDI's are a lot more sensitive to a failing MAF than the petrol engined models so it's really not worth the risk.
  28. Westy
    17,443
    1,105
    Wouldn't a larger TIP and filter allow the turbo to flow better and therefore pull more air across the MAF giving a higher reading? Even though the MAF tube remains the same size it should see extra airflow or am I missing something?
    You'll have to excuse me as I've no experience of any of the 8P engines.
  29. warren_S5
    7,210
    2,488
    This is 2.0T again, but gives you a pipe by pipe breakdown of the dev work done on my last S3 LINK
    Westy likes this.
  30. Westy
    17,443
    1,105
    Great info Warren thanks.
    That's what I'm talking about, reducing the restrictions all the way from turbo to filter. Removes the bottle neck and the large open filter allows a lot more air in then any closed airbox can.
    I can now see the differences with the 2.0T compared to the 1.8T. Your MAF is not mounted in a tube (one piece) like on the 1.8T is it? It's a thin elelement that slides into the side of an existing tube. So you can't just start using silicone reducers and the like to attach a bigger necked filter.
    Big learning curve this ;)
  31. JJ.Foulds
    1,263
    176
