£149 Sports CAT's
docurley Nov 15, 2005
  1. docurley
    4,073
    88
    Found this on ebay.
    Sport CAT
    The bore is one size so ignore what’s on there but they stock different size CAT's depending on engine size and what space is available so Greg what’s your size as I'm have my system made up for me X-Mass prezz and want the correct size now ready for the GT28RS setup later in the New Year.
    Also there will be no flanges just the pipes coming out so this has to be custom mounted.
  2. PaulJC84
    PaulJC84 Owner
    2,921
    17
    That could be very handy!!
    I would just mount it in the centre section so its easy to remove etc.
    Cheers.
  3. docurley
    4,073
    88
    Has I understand the CAT's work better nearer the Turbo!!!
  4. PaulJC84
    PaulJC84 Owner
    2,921
    17
    Oh right how did you find that out?
    Cos on some Imprezza people remove both CAT's and just put one in the centre section for the MOT.
    Cheers.
  5. docurley
    4,073
    88
    I only read it someware but it may not be true and like you it may be the way to go and mount it else where.
  6. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    The cat will get hotter, sooner the closer to the manifold/turbo it is, meaning that it will work quicker from cold than if it were half way down the car.
    Rich
  7. docurley
    4,073
    88
    So what your saying is that it’s more environmentally friendly nearer to the Turbo but make no difference to performance!
  8. RichA3Turbo
    5,089
    Pretty much. A restriction is a restriction wherever it is! Cant see placement making any difference whatsoever
  9. docurley
    4,073
    88
    Great that resolves that issue and less heat build up under the hood if relocated under the car.
  10. PaulJC84
    PaulJC84 Owner
    2,921
    17
    It will be interesting to see how good (efficient) this CAT is since its pretty cheap.
    Also how do you know it is a sorts cat? Is it like 100 or 200 cell?
    Cheers.
