Barker_Tom
Hi chaps,
I have just just bought an early, unmodified 1999 S3 (210 model) on 88K miles. It has been a while since I last owned a Turbo car, having just passed off my excellent 172 Cup in favour of the Audi.
I have a few questions to ask you guys who no doubt know a bit more about German cars than I do - Although I have done my time playing with French engines (had a whole string of R5GTTs.....) so I am not entirely simple.
Anyway...
- When warmed up my idle is lumpy, dropping between 500rpm-900rpm. Also when selecting neutral from another gear, the engine speeds drops right down to 200rpm ish (almost stalling) and then picks up to idle again.
- Boost is lumpy, when accelerating I get quite major flat spots, especially after I have been thrashing it a bit. I can hear flutter/chatter quite loud when letting of the throttle, I thought at firs there may be a boost leak, but now I think that maybe the flat spots are caused by pinking/knock sensor?? - as I am using cheap 95ron fuel (should the S3 use Optimax or equivalent?).
- It has that common sound on start up...like a bag of nails (only for a split second), but sounds OK thereafter...
I have the day off tomorow when I am changing the track rod ends and front discs. I'm also going to give the engine bay a clean and look over.
I thought it may be worth asking for advice before I start taking the inlet tract apart looking for problems.... (I don't want to break anything - I need to get to work on Thursday!).
Many thanks for any help that you can offer,
I plan to spend all day saturday cleaning and polishing the car, so I will post some pictures up.
Tom.
Anyway...
Tom.
