Hi guys,
As most probably already know, there isn't really a lot of choice when it comes to bolt-on big brakes for B5 fronts. Most popular option so far is A6 / TT carriers to space the original calipers out, to accept 312mm discs.
I'm currently developing a big Brembo bolt-on kit for B5 cars, including S4.
Kit will consist of:
A pair of 4-piston Brembos.
A pair of Brembo-to-B5 A4 / S4 adapters.
A pair of discs in 288 / 315 / 330 / 365 / 380mm (dependent on current wheel size).
A pair of braided brake lines.
A set of pads, either Mintex, Brembo or Hawk.
Titanium mounting bolts.
Synthetic brake fluid.
Discs, apart from the choice of size, will be available as one-piece, or two-piece with central bells.
Minimum wheel size will be 16" for 288mm, rising to 19" for 380mm set-up
There'll also be a choice of solid or slotted.
I shall not be offering drilled items - I've run them in the past, and they have a tendency to crack between the holes.
Brembo calipers will be available in black or red.
I'm doing the development on my own car.
The kits will be available for both quattro and front track B5.
If anyone is interested, please register interest here.
Price wise, I'll know more once mine is done.
I'll also be putting them through their paces in terms of testing.
Not sure if this can be made a sticky by moderators, will be good if it can be done.
Thanks for reading.
Thanks for reading.
