I have some pixel lines missing on my DIS. This seems to go from bad to worse. Recently i have had oil sensor warnings apear along with various other faults which in turn set the alarm off all the time. After taking it to TT shop, they put it on the vag com where it showed no faults. There diagnosis was that i had a dash pod defect, as the pod controls all the fault indications and the immobiliser is also controlled through this. Makes sense.
This is a recognised fault on the MK1 TT and Audi UK will replace the dashpod under warranty regardless of the car age. So i rang up Audi Uk and asked if they would replace the S3 dashpod under warranty as they do with the TT.
The response was negative, they replied that where it is recognised as a fault in the MK1 TT they are not aware of the A3/S3 model suffering such problems.
I would love to know if this is a common fault between S3 owners. And if so maybe we can pertition to have the fault fixed under warranty as TT owners did on a forum site.
